Old 09-23-2008, 06:17 PM   #1
JQ-72
JQ-72's Avatar
402 BB 4 sale in NW ALA.
402 big block taken out of a 1970 1/2 ton Suburban. Here's the deal: It was running when I got it, but had a knock in it. I tore it down and #3 rod bearing spun and scarred up the crank pretty bad. I took it to a machine shop and had the following work done : heads reworked, block checked and left on standard bore (very small ring groove), new cam bearings and freeze plugs installed. I bought a used STEEL crank and had it turned .010/.010. I also have good used cam, lifters, timing chain. It just needs rings and bearings and put back together. Includes intake and distributor. No pulleys, brackets, or carb. $800. I can get pics if needed.
Joshua
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track
72 Cheyenne Super swb. 350/350 A/C, bucket seats
72 Cheyenne swb. Factory 402/400, tilt, posi, A/C
72 Cheyenne Super K-10. 350/4 spd., posi.
72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack
72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior
JQ-72 is offline   Reply With Quote
