Old 09-27-2008, 12:55 PM   #1
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Popping sound in control arm
I've been driving my truck a lot lately, and she's developed a quite annoying popping noise in the drivers side lower control arm. It sounds like someone is hitting a vise with a ball peen hammer. I'm headed to nappa to order new control arm shafts, as thats about the only thing that isn't brand-spankin new on my front end. Anybody else have this problem?
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 09-27-2008, 01:01 PM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: Popping sound in control arm
Are your springs cut? When I cut mine they used to bounce around in the pocket when I went over bumps too quickly. Just a thought. I also had a pop like you described once and it turned out to be the nuts that hold the shims in place. Hope you get it figured out.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 09-27-2008, 01:09 PM   #3
dieselarmy13
My springs do have one coil cut off. I was thinking that's what it was, but it takes very little movement to cause it. I'll check the nuts too.
Old 09-27-2008, 07:21 PM   #4
beautimus
beautimus's Avatar
have you checked the u bolts that hold the lower control arm shaft in place? the control arm can shift if the u bolt works loose. not to mention the old u bolt breaking thing.
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
Old 09-27-2008, 07:33 PM   #5
Lower ball joint? I have seen and heard a couple where they would pop loose from the press-in fitting area, then pop back into place later
Old 09-27-2008, 07:35 PM   #6
uncle
Ball joints will also do this when not enough grease is used.
uncle is offline   Reply With Quote
Old 09-28-2008, 04:40 AM   #7
OhioDan
OhioDan's Avatar
Lube the front end. Sounds like a dry ball joint? Did that once on a 70 Nova.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 09-28-2008, 05:00 AM   #8
racin69z
racin69z's Avatar
I had that happen once in my camaro. It turned out to be a loose fit where the ball joint pushed into the control arm.
racin69z is offline   Reply With Quote
Old 09-28-2008, 09:06 AM   #9
haysonj
haysonj's Avatar
I don't know about these years but on my 85 one ton I replaced the a arm and did not get the spring located in the right spot. drove me crazy until I took it to an alignment shop and they found it.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
