Old 10-05-2008, 05:54 PM   #1
MNorby
MNorby's Avatar
door assembly?
My doors on the 71 are in bad shape. I;ve never run them on the rig since I got it and its getting cold and time to fix them u p. I cut the bottom of the door off (boatsided the rig they go on) and out cames a bunch of plates, spring, the door button, etc. is there a diagram to show how everything is supposed to be assembled inside the door somewhere? thanks
MNorby is offline   Reply With Quote
Old 10-05-2008, 07:27 PM   #2
Riveted1
Tasty Cakes!
Riveted1's Avatar
Re: door assembly?
Something like this? Door
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 10-05-2008, 10:29 PM   #3
MNorby
MNorby's Avatar
Re: door assembly?
kinda but not really. Both doors had a spring with a screw looking deal stuck in the end siting in the bottom of the door along with an oval plate and the door buttons. do the buttons just sit in the handle?
Old 10-06-2008, 05:13 AM   #4
JimKshortstep4x4
Re: door assembly?
It sounds like the door handles came apart and the parts fell down. The parts you are looking at were staked onto the door handle by bending tabs over the plate which held the plunger and spring. The door handle is a die cast part so getting the parts to stay in after the tabs break is usually not worth the effort. I would suggest getting different door handles and tossing the old ones.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 10-06-2008, 08:31 PM   #5
MNorby
MNorby's Avatar
Re: door assembly?
i don't think its that bad. I can stick my finger in the hood handle button hole and push the lever and open from outside and the inside door handle works. Here are pics of the pieces I'm talking about. Not sure if the button just sits in there or what.
Old 10-07-2008, 12:22 AM   #6
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Re: door assembly?
That oval looking thing is the backing plate to a sport mirror. The little clip with the hole in the end goes on the rod that runs from your inside door handle back to the actuator. the other 2 items belong to the door handle. Pick up a used pair of handles on the parts board. Since your wheelin yours, they don't need to be all shiney.
low'n slow is offline   Reply With Quote
Old 10-10-2008, 10:22 PM   #7
MNorby
MNorby's Avatar
Re: door assembly?
is there any way to just put the parts back in or are they broke?
Old 10-11-2008, 03:41 AM   #8
ERASER5
ERASER5's Avatar
Re: door assembly?
Broken. Sad, but true.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 10-11-2008, 07:41 PM   #9
MNorby
MNorby's Avatar
Re: door assembly?
doh. Both my door handle look like this too.
see if I can fond someone who replaced rusty ones i guess then
