Roof Rack Question.
Does anyone have a GM accessory part number for the Suburban Roof Rack? I am trying to figure out some details, but am having some difficulty. I know at some point they had the one that kind of leaned forward in the front, then they changed to the ones that kind of leaned backwards in the front. I am really more interested in the one that kind of leaned forward. I don't understand what the difference in the number of feet is. I have seen some that have 2 feet per side, and others that have 3 feet per side. I also would like to know the dimensions of the suburban roof rack if possible. I know the blazer one is shorter, but I don't know how much shorter. If anyone could help me out I would really appreciate it. Pics are always nice if available, but I would really just be happy with an explanation at this point.
Thanks! Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE Last edited by jorgensensc; 10-12-2008 at 09:13 AM. |
member #16
![]() Join Date: Dec 1999
Re: Roof Rack Question.
frizzle fry has one on his truck.
http://67-72chevytrucks.com/vboard/member.php?u=18620
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
THanks John.
Anyone else got any info?
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
![]() Join Date: Apr 2005
"Most" of the suburban ones have 3 feet per side. The only difference in the leaning forward and the leaning rearward are the 2 front feet and you can swap them out. Overall length is approximately 64". Here's pictures of both:
EDIT. Looks like the middle foot doesn't lean either, but if you found 2 front feet I'm not sure how much you would notice it.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 10-13-2008 at 11:35 AM. |
