Old 08-31-2008, 11:41 AM   #1
drummin89
drummin89's Avatar
steering columns
LETS SEE THEM!!! For both Advanced Design and Task Force trucks. What did you get it out of and how easy/hard was it to adapt to these trucks.
I like the look of those aftermarket tilt columns but not the price. I live with in miles of a large U-Pull-It yard that has thousands of cars and trucks of every make, mainly 80's to late 90's/early 2000's. I went today looking at what could be used and seen a few that may work, but would like to see what everyone else is using in their trucks.
Chris
52 Chevy 3600 (3/4 ton) 5 window pickup
-54 235 Inline 6 w/ Fuel Injection Conversion
-Clifford 2/4bbl Aluminum Intake and Headers
-1/2 ton front axle swap w/ 5lug disc brake kit
-CPP Power Steering Kit
Various pictures of my 52 Chevy 3600
drummin89 is offline   Reply With Quote
Old 08-31-2008, 10:55 PM   #2
54 jimmy
54 jimmy's Avatar
Re: steering columns
if you want something that goes right in and uses the stock clampsthe use a 68 chevy pickup column. this is what i did mine was a 3 on the tree but i took care of that since i am using an auto with a floor shift.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 09-01-2008, 01:17 AM   #3
Daniel U
Daniel U's Avatar
Not sure if this came out of a van or truck, but it's a "GM" steering column.
I'm thinking from 70's. It fit's well in my '54 AD truck
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 09-01-2008, 07:26 AM   #4
drummin89
drummin89's Avatar
I would like it to be able to just bolt in like the stock column, but if I can find anything that does, I do have some decent fab skills and access to everything I should need to make it work.
Is that 68 pickup column tilt, its hard to tell from that picture.
Thanks for the replies
Chris
Old 09-01-2008, 08:01 AM   #5
54 jimmy
54 jimmy's Avatar
no tilt on my column but a tilt one should fit the same.
Old 09-01-2008, 04:22 PM   #6
8ball
8ball's Avatar
I modified the stock column by removing the steering box from my 1948 column and machining the shaft end to fit a double D style universal joint. It seemed pretty simple and cheap. I bought the bearing end from Classic Parts:
http://www.classicparts.com/1947-59-...ctinfo/76-987/
I moved the column down in firewall to clear the headers. Here's a pic
8ball is offline   Reply With Quote
Old 09-01-2008, 11:51 PM   #7
MrSinister
MrSinister's Avatar
These are before and after shots. Went from mid 70's chevy van tilt to Ididit column shift. Both were pretty easy the van fit in the stock upper mount and I made a simple plate for the bottom. I used a Borgeson drop that bolted into the stock upper holes and made another bottom plate and used an Ididit swivel mount for the new.
'56 Big window
350/700r4
9" rear w/disc
MrSinister is offline   Reply With Quote
Old 10-10-2008, 02:38 AM   #8
ccpanel
pic on its way-i did that in my 1951 panel truck in 1996. Went to my loacl bearing shop and fabbed my own setup. I built in a retainer before i sealed in bearing to keep steering shaft from sliding down the tube and makeing teh steering wheel a thrust bearing surface...
Mark
ccpanel is offline   Reply With Quote
Old 10-14-2008, 08:37 PM   #9
mcarrel
Here is a 57 with 71 Chevy tilt column a little harder to find but are out there. I got this one for $80 came out of a motorhome with 50 k on it will still have the key in the dash.
mcarrel is offline   Reply With Quote
