1"/3" drop
I have 1" drop coils on the front of my frame and 3" drop on the rear. Without the body on, it looks like it's got a fairly level stance. Does anyone have a picture of a truck with a 1/3 drop with all the parts on it and weighted down?
Thank, Greg
69 SWB LT1/4L60E www.classicplace.com |
Fabricate till you "puke"
From what i have seen on these trucks, it takes approx 2-2 1/2" more drop at the rear to make a level stance. I have hwat i would call "loosely" a 3/5 drop on the longhorn(no aftermarket parts), & she has 1" more height at the rear. Tire height is also a factor on the stance, but I would say you should have a fairly level stance. Sorry I cant help with the pics that you need to see tho.....
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Almost Satisfied
![]() Join Date: Mar 2002
what kind of fuel tank do you have in your truck minibike?
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
Spank 'em if you got 'em!
I'd like to know what tank that is also. It looks metal.
Long Knight '71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick |
Appreciate the help longhorn...
The tank was custom made by a local boat builder. I have a fuel injected LT1, so needed to have a tank built around a Camaro in tank fuel pump. At $215, it was pretty reasonable. Greg
"Ochre Ogre"
From what i have been told, you will not see a change in height with a 1" drop spring. After 30 years, your old springs have sagged that much already. As for a level stance, it should be close with a 1-3 drop. Worst case is you add a spacer at the rear axle to fine tune it.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
