Barn find resurrection
Yesterday I started on my new project of bringing back to life a 1970 short step 2 wheel drive. Removed the box, then removed the engine. I found why it was in the barn. Can any one tell me what these heads are by the numbers in the pictures?
BlahBlahBlah
Re: Barn find resurrection
333882.....74-80...350/400......76cc chambers
Looked it up on Mortec.com |
I THINK those are 283 heads...? Do you know what type of motor is in there or that's what your trying to figure out?
R.I.P. Scott Kalitta
It was in this pickup when I bought it . ## show it came with a six, so I'm un sure what it is. I was thinking of using the heads on up to the carb on another block that I have. Depends what I have.
Luv the Crewcabs
Look's Like a Good Start, Good Luck with it, Look forward to more Pics & Detail...............
Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
BlahBlahBlah
If I read the numbers right on your block picture here is what it is.
3970014....350...70-76...2 or 4 |
The 882's are definitely a 350/400 head from the smog era (1974-80) and don't get too much love as a performance head. I'd use them on a cruiser if you didn't have to put any $ into them.
They call me the Breeze...
![]() Join Date: Jul 2007
Looks like a nice project, good luck.
Mike 69 K20 "Beer is proof God loves us and wants us to be happy"....Ben Franklin |
67 is sold
Nice truck
![]() Here is some info I dug up on the heads: Casting | No Years | CID | Intake | Exhaust | CC 333882 | 1970-80 | 350/400 | 1.94 | 1.5 | 76 http://www.chevy-camaro.com/chevy-ca...es.asp?group=6 |
Tot Roddin'
What a score!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Its a good thing the motor had problems, it helped keep the truck in real good shape.
Thanks for the ID help guys. It came with another block and heads. I'll tear it down this weekend to see what it's made of.
Out of the carpool lane.
It looks like you only like 72's so I'll come by this weekend and pick that old junk truck up from you.
![]() Looks like a sweet project!
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
The 882 heads have reputation of cracking between the valve seats. Instead of putting any money back into the heads you might want to find some replacements. The 993 casting is a better bet for durability but some 441 or 487 castings would give you better flow/performance.
Have fun with your new project. It does not look like it needs too much to be back on the road. |
#15 |
Tonight I will pull the covers off the spare engine and see what ## it has on the heads.
#16 |
#17 | |
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
#18 |
don't knock 882 heads. have used them alot in the past making some great horsepower. granted they are not the same as newer cheaper heads they are still good. slap some screwin studs and new valves and some domed topped 10.5 pistons and with the reight springs you will have a 7200 rpm. the 76cc heads are for the smog cars but can be built to be a very low buck continder. just my 2 cents.
#19 |
took the covers off the other engine. Same heads, different block.
#20 |
That one shows to be a 77-79 350 2 or 4 bolt block.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#21 |
ha ha... jorgensensc beat me to it!
#22 |
I'll have to pull it apart to check it out and clean it up after work tonight. Hope it's a 4 bolt.
#23 |
I was searching for another engine option today and came across a 350 runner that he said came out of a early 70's pickup. I gave $100 for it. What do these ## tell it is??
#24 |
I don't know about the years but a 3970010 is a 350 that usually is a four bolt block. But not always.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
#25 |
I'll know sunday if its a 4 bolt. I'm going to tear it down and rebuild this one.
