Old 12-15-2008, 05:33 PM   #1
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Talking How do I know what Engine I have?
Okay so like having a 6 banger is not all bad right?
Well might as well keep it since it doesn't smoke too bad or burn too much oil. So where do look for numbers on this sucker that could help me learn what motor I have under the hood of my '67 Chevy pick'em up truck?
Thanks in advance!
Here is the engine ( and yeah I know its UGLY)
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 12-15-2008, 06:24 PM   #2
mvfd70
mvfd70's Avatar
Re: How do I know what Engine I have?
Easiest way to tell is look at the engine mounts. If they are straight across from each other then its a 250. If the passenger side mount is more towards the radiator than the drivers side, then it's a 292. Also the 292 block is a little taller than the 250.
Unless someone has put an older 235 (I'm sure someone somewhere has done it before) in there.
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 12-15-2008, 06:29 PM   #3
69sixpackbee
What does the sticker on the valve cover say? (
69sixpackbee is offline   Reply With Quote
Old 12-15-2008, 06:30 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
The side covers for the lifters will be 6 in on the 292 but only 4 in on a 250.After a while it becomes second nature just like looking at BB and SB engines.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-15-2008, 06:35 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
It's not a 235 Stovebolt series.
It's not a 292, lacking the large bypass hose off the waterpump and thermostat housing.
That means it's either a 230 or a 250.
You'll have to run the serial number to find out which one.
The number is on the passenger side near the oil pressure port.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-15-2008, 06:42 PM   #6
Stock72c10
classic=of recognized value
Stock72c10's Avatar
To answer you first question, no, a six is not all bad at all. I actually really like mine and it sounds great when I cruise next to the median barrier on the highway (especially when it lugs down). They get good gas mileage, have lots of torque, and are very easy to work on. One downside is they are more expensive to modify then a 350, but I like mine the way it is so that is not an issue for me.
By the way, I think yours is a 250 ci (4.1 L).
Stock72c10 is offline   Reply With Quote
