Old 05-13-2002, 09:46 PM   #1
gabet40
Post starting the engine with out the tranny in?
i have my tranny pulled out but my engine is still mounted. is it ok to run it? or do i have to worry about it falling forward or backwards? because the tranny is what stabilized it from that. and is the flywheel ok as long as theres nothing in the way? thanx in advance
69 1/2 ton, 350 with Accel DFI intake,crane powermax cam, 700r4 with lock up torque converter, change from long/fleet to short/fleet, shaved door handles, custom sounds, dual headman blockhuggers/flowmasters exhaust, shaved tailgate, 18" budniks with matching steering wheel, 4/6 drop, power windows
Current owner of 2016 2500 Silverado Midnight Edition.
Former owner of:
69 1/2 ton, change from long/fleet to short/fleet, shaved door handles, shaved tailgate, 4/6 drop, power windows, 700r4
72 blazer, 350 with Holley Commander 950 DFI, crane energizer cam, 350 tranny, dual sanderson blockhuggers/magnaflow exhaust
gabet40 is offline   Reply With Quote
Old 05-13-2002, 10:05 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
Just set the engine on something kinda tall. I used a large coffee can under a Camaro, and a bottle jack under the old Longhorn. If your engine is only beeing supported by your exhaust and motor mounts, you better go do something now. They will all be junk. I busted my ram horns, and destroied my motor mounts by keein it like that for about 3 months.
However, you are right, as long as your fly wheel is clear, you can start it. I wouldn't romp on the gas too hard, you are missing a mounting point there.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
E-mail longhornmail@yahoo.com
My name is Andy...not Randy...I'm in Ohio...Not Illinois...close enough?
Columbus Ohio
Old 05-13-2002, 10:11 PM   #3
Fast68Chevy
Fast68Chevy's Avatar
Post
nothing wrong with that as long as you dont break any of the above items, mounts or manifold,s etc. i once started up an engine minus oil pan and timing cover, etc, yeah.... was a 1969 Ford 240 engine.. back when i didnt know any better. it ran nevber locked up or squeaked or anything, i eventually put it back together and drove the truck again, the engine outlasted the body. i eventually disassembled engine for the last time after the front clip fell apart.
good luck!
Randy- Lincoln, IL
randy@ccaonline.com 2177353230
*many GM parts bought, traded, or sold -am parting out: '81 Cutlass Supreme Brougham
current fleet: -71 C-10 350/CH465/3.07- basketcase, #1
-90 Cavalier 2.2L sky blue, a driver
-84 Z28 5.0L/700R4/3.73 daily driver
-84 Firebird/SE 2.8L/T-5/3.73/engine bad, project #2
-82 purple Trans Am, project #3
*Paint is overrated*
© RSS Enterprises 2000
Fast68Chevy is offline   Reply With Quote
