Old 02-05-2009, 10:36 PM   #1
heavy71chevy
heavy71chevy's Avatar
Muncie 4 speed swap ?'s
Ok guys this is a new realm for me but what is a list of swap parts and steps to putting a close ratio muncie 4 speed into a 71 c10 that was originally a small block truck with a turbo 350?Its going behind a mild tunnel ram 350..need help do I can start rounded up the parts
"Dixie Destroyer"
71 C10 LWB Fleet
Future Blown Prostreet Monster
heavy71chevy is offline   Reply With Quote
Old 02-06-2009, 11:55 PM   #2
heavy71chevy
Re: Muncie 4 speed swap ?'s
ttt ??
"Dixie Destroyer"
71 C10 LWB Fleet
Old 02-07-2009, 12:08 AM   #3
Cyclone
Cyclone's Avatar
pm tranz am, he had one in his till the 5sp swap.
Cyclone is offline   Reply With Quote
Old 02-07-2009, 12:53 AM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Here's a couple of threads but not really a lot of info...
http://67-72chevytrucks.com/vboard/s...ghlight=muncie
LockDoc
Leon
Old 02-07-2009, 06:38 AM   #5
Those transmissions bolt right in where a 3spd was.So,get all the 3spd parts and bolt it in.I like to use an automatic crossmember with the rear trans mount and car bellhousing.
Old 02-07-2009, 07:08 AM   #6
heavy71chevy
What all do I need from the 3 speed truck? and thanks for the replys yall
"Dixie Destroyer"
71 C10 LWB Fleet
Old 02-07-2009, 07:17 AM   #7
71chevytruckguy
71chevytruckguy's Avatar
I swapped from a 3 spd to 4 muncie. Its great till ya start really shifting them and ya blow them up.
but, you'll need from a parts truck, the clutch/brake pedals, clutch pedal to z-bar linkage, z-bar, z-bar frame mount, z-bar eninge pivot, z-bar to clutch fork linkage, clutch fork.
from some where else, you'll need a chevy car bellhousing, pilot bushing, flywheel, clutch disc, pressure plate, throwout bearing. shoule be able to use the starter ya got if bolts to bolt, think auto do, never messed with one. of course you'll need a shifter, hurst makes one for puttin muncies in these year trucks that works great. your driveshaft should work, might have to change the yoke depened on what year muncie you get, they have to different size outputs. think that should about do it. got any other questions, ask. Chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 02-07-2009, 08:33 AM   #8
Yeah,I think it`s the M22 has a fine spline,same as TH400.
Old 02-07-2009, 10:41 AM   #9
breeh
Recovering 67-72 Addict
breeh's Avatar
All of the later Muncies had fine spline. I think that began around '70 or '71. The only reliable way to ID M-22's is to pull the side cover and look at the gears. It seems that every Muncie I see at swap meets, CL, etc. is claimed to be an M-22
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
