ok i did a tranny and t case swap converted a auto to manual
im useing a ford drive shaft (its the only way to go with out getting one made) i know the u joint that goes in the output in the t case (dana20 t case) has to be 3 1/2 long and for the drive shaft is 4'' where the ujoint goes in i think its like 3 3/4 long or somthin odd like that anyone know any u joint conversion i have a chevy to ford on the other end of the dirve shaft that goes to the rear end |
One shot, one kill.
Re: u joint help please help
Shane. I would stop pulling my hair out over this. "make it fit" U joints are a PITA. You have to buy 2 of each so you have a replacement part, and then what happens if they stop makeing it? Have the shaft that was in the truck altered to fit using the correct "U" joint for your application. You might need to buy another shaft to get the correct ends, but in the long run it will be easier and cheaper. Who knows, you might just find a shaft that fits right in, right? Check your local scrap yards. My 2 pennys, jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shot ![]() |
Tags |
u joint help |
