Old 02-19-2009, 10:45 AM   #1
tbrown5079
Primer of choice
All the replacement panels are in and everything is aligned so now we are taking it apart to primer before body filler. What is the primer of choice? Epoxy, eurothane, etc. Brand?
tbrown5079 is offline   Reply With Quote
Old 02-19-2009, 11:02 AM   #2
bensimmons_05
bensimmons_05's Avatar
Re: Primer of choice
The epoxy primer is some really good stuff, but if you use it make sure you have PLENTY of sand paper on hand. All the epoxy I have ever used loves to load the sand paper up!
---Ben Jammin's 1955 Chevy/GMC Project ---
---The shop's live video feed--- <<< See what I'm up to!
bensimmons_05 is offline   Reply With Quote
Old 02-19-2009, 11:20 AM   #3
bensimmons_05
... And if you are laying mud OVER the primer the epoxy is a good choice
Old 02-19-2009, 11:59 AM   #4
63 & 64 Bowties
and a few others
just a suggestion....you may want to check in the Paint and Body forum for lots of opinions/suggestions.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 02-19-2009, 01:54 PM   #5
mylow53
mylow53's Avatar
one thing i learned about primer use something bright don't go black like i did. it became hard to see what i was doing unless i had a light. if i could do it again i would use a brighter color
GT
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 02-19-2009, 02:06 PM   #6
bensimmons_05
Hey GT, I have found that the use of a guide coat helps a great deal on either light or dark primer. For black.. you can get a cheap can of white spray paint and lightly mist it over the area. Then you can see high and low spots when you sand and where needs to be sanded more.
Old 02-19-2009, 02:08 PM   #7
OrrieG
OrrieG's Avatar
Also look in FAQ archive for MartinSR Basics series on autobody. Third option is to talk to the counter guy at your paint store. He can give you real world information on what works in your area and what different price points mean in terms of labor and final quality. I spent $150 on one gallon of etch and one gallon of fill/sanding primer and associated activators. The first is has a yellow tint, second light grey so I can tell high spots.
Old 02-19-2009, 02:29 PM   #8
mylow53
mylow53's Avatar
roger than ben. my problem was working in the garage on areas under the dash i couln't see a thing with out the light.
GT
Greg
Old 02-19-2009, 02:45 PM   #9
bensimmons_05
ohhhh IC
