Old 02-07-2009, 05:49 PM   #1
longhorn_SD69
longhorn_SD69's Avatar
Project build"er up
WHATS up dudes. so here's the deal as many might know i just picked up my second 69 Longhorn.... I'm going far from original with is since i have one already thats pretty close to orginal. So i'm starting from the ground up the truck is broke down to a cab on a frame right now. I'm adding a new beefier suspension that's going to lift the truck two inches from original height and i'm adding front end leaf springs. how difficult is the conversion from the standard from end to leafs other than the conversion to 4wd which means i need to add a front axle?
Good Wood
longhorn_SD69 is offline   Reply With Quote
Old 02-07-2009, 07:54 PM   #2
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: Project build"er up
You would need to get a front axle from a bigger(over 1-ton) or older truck(pre-60).
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
