huh?
![]() Join Date: May 2000
Well, the top things on my list today were getting the left rear tire changed...DONE...and getting power to the interior....DONE....
I can't believe the mess of wiring under that hood! Previous moron owners need to be shot. There was a wire coming from the battery, going into the interior, and coming out between the steering column, and it's sealing grommet. There was another wire going from the fusebox feed wire, through the harness, down by the voltage reg, and looping back around into the interior. This wire also came out in the same spot. They were both cut off??? So, I got rid of the excess wire, and hooked the 2 together....we have power...cool... The only thing that bugs me is that I don't know why the truck was set up like that.... I also had to fix the blue wire that goes from the regulator to the alternator plug. It was running through a HOSE, to the alternator. I pulled it off, and it was totally melted. Now, to my question: Does anyone have pics of a 3 spd column linkage setup? Mine is all unhooked, and a mess. Any help would be greatly appreciated! Thanks, TJ ------------------ 68 C10 Short Step (Christine), 406 SB, TH350, 3.73's, currently going on the back burner. New to my fleet, 67 C10 Panel (1 of 3827) (Nicknamed the laggin wagon, thanks to Josh, the webmaster), 292, p/s, speed, 86,000 orig. miles Gridley, IL bigbad406@msn.com I'm on MSN messenger under that address if you would like to add me...... Also on AOL IM under the nick tommy85z My Personal Homepage The 67-72 gallery on MSN, feel free to submit your pics! A pass-time of mine is storm spotting, click here to see Gridley IL's Emergency Services Homepage. AOL SN- Tommy85z
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
