700R4. Love it or hate it?
Do you regret your 700R4 swap? Do you love your 700R4 swap?
I'm thinking hard about it. I don't want recommendations on what tranny to keep or buy or rebuild, there are plenty of threads with lots of good info about transmissions. I'm just interested in whether you love or hate your 700R4 and why.
Curry in a Hurry: SB rebuild for my 71 C20 |
Moderator
![]() Join Date: May 2007
Re: 700R4. Love it or hate it?
Love it. Shifts great, low first gear, better mileage on the freeway.
Love it too. I don't think I like the low first gear so much... or rather the big jump between 1st and second since I don't do a lot of heavy hauling. But the overdrive is wonderful, as it makes the truck into a very friendly highway cruiser.
I love my 700r4 wouldnt trade it for nothin in the world
Hated it!! when I had my 89 gmc with a "355" I went thru two of them in less than 5k miles,,,never again.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
![]() Join Date: Nov 2004
Yes, I regret it, but ONLY because I wish I had done a 5 speed swap more (I like driving manuals) but now that it's in I love it.
I installed an old junkyard one from an '83 firebird with high miles and didn't have the TV cable set up right and it burned up after 7K. The "new one" has about 8K on it and going strong still.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 02-17-2009 at 01:09 AM. |
Sisyphus was my mentor!
![]() Join Date: Sep 2002
Love it. Once the 700r4 has been rebuilt with good guts, you can drive it hard & it will last for a long time. I drove mine for 11 years daily for about 80000kms & I drove it hard, grabbing rubber in the first 2 gears all the time. It makes a buzzy highway drive a pleasure. The low 1st gear can be coupled with a 3.08 rear gear that still gets ya moving fast & then at the other end, get those highway rpms down close to a gas-sipping 1500rpm. The caveat, it can’t be stock or it wont live very long – it needs to be rebuilt! It can be built to withstand 700hp I'm told...
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car Last edited by passthebuck; 02-17-2009 at 01:12 AM. Reason: Spelling |
Too many projects
I love mine in my chevelle. Low first gear makes my 3.08s reasonable and the OD lets me get 20mpg at 75 (turning 2300 rpms).
Great tranny, just not sure how much it can be beefed up for loads of power.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
I have a radical idea!
I totally agree with this post. I know you said you don't want tranny recomendations, but its hard to accurately answer your question without saying this. To answer your question, I have done 700 swaps and they are OK. However, I'd much rather have a 200-4R. The 200-4R is just as strong (and can be built way stronger if needed) but is basically geared like a TH350 with an OD. As Indyuke said, the massive jump in ratio between 1st and 2nd in a 700 is annoying to me. The 200 is the same length as the TH350 so the driveshaft doesn't have to changed, and it uses the same lockup wiring as a 700. I've done them both and in short, the 700-R4 swaps were just OK - the 200-4R swaps were great!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
I hato agree with 67 C30, I have had experience with both the 700R4 and 200-4R and I must say that the 200-4R is a way nicer trans in every way
1. better gear spacing 2. direct swap (uses TH350 driveshaft and TH400 mount location) 3. Multi-fit case 4. a little more OD .67 compared to .70 5. you can usually find them at a wrecker in a non abused oldsmobile from the 80's with a wimpy 307 in front of it. |
resident oilfield trash
Love that Overdrive
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() |
Moderator
Lots of good points here, both positive and negative. It works for me cause I like the low first gear combined with my 3.08 gears. I do mostly in town driving, so I smoke the rice burners light to light, and still get the benefits of road trips on the freeway. 2200 rpm at 70 mph
![]() I do have to add that they are tempermental and require a precise set-up, or they will fry in a heartbeat. Last edited by leddzepp; 02-17-2009 at 03:18 AM. |
#13 | |
He means the position of the TV cable. It controls shifting on them, and if it is not set properly, you'll lunch one in a hurry.
#15 |
sharp as a marble
![]() Join Date: Jan 2007
I had one in my 500hp Chevelle, have one in my 72 Blazer, and am headed towards one in my C-10. The only way to go. You do need to get the TV cable adjusted correctly or you can burn them up. A little patience and the RPM and noise reduction is GREAT
#16 |
Eat My Rust
It out lasted the motor in my Firebird at 275k miles. Still no slipping after I sold it, and i beat the hell out of that car.
#17 |
WTB this ad
I agree with 67 C-30. The 200 has a lot less lag from first to second and seem to be the way people are leaning these days instead of the 700.
#18 |
I have one in my 65 Chevy II and I love it. I have 3.08 gears in it and I really like the low first gear. The difference between 1st and 2nd doesn't seem like much to me, maybe because of the 3.08s.
Hail to the King, baby. |
#19 |
Old member
Put a good rebuilt 700-R4 in a truck with 4:11 gears and decide for your self.
Enough said! ![]() ![]() ![]() ![]() ![]() ![]() I LOVE IT! Anybody who likes auto's and say they didn't like the 700's didn't have it done right in my opinion.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#20 |
Dork For Days
I've got one in my C20 with the factory Dana 3.54s out back, but I've got some fairly tall tires. I've reduced the diameter from stock a bit, but they're still pretty tall. I'm running 285/60-17s and they look really tough.
I love the low 1st gear for towing, although I rarely do any of it. At least I'm ready for it! Dropping it into OD with the converter locked up is a treat. It drops the RPMs by a huge amount. I'm not sure how much since I don't have a tach, but it's very significant.
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status! ![]() 1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60' 2007 Dodge Charger SRT-8 2008 Cadillac CTS All-American garage, baby! |
#21 |
what is a reasonable price that you guys have paid for a 700r4 rebuild, also what type of vehicle do the 200-r4's come in!!
#22 |
![]() Join Date: Dec 2008
I agree with the previous posts, and definately disagree with anyone who toasted two...Built and Installed correctly that would not have happened...I pull a 16 foot Gooseneck dump trailer with mine almost everyday in a 95 2500, loaded weight of 8,000 Lbs., through mud in 4wd and have only rebuilt once in 180,000 miles, Love it & can't hurt em if you know how to drive. My $.02
#23 |
Gearhead
Also love mine, made a huge difference in drivability and highway comfort. I have not had any issues at all, but TV Cable set-up is critical, and mine has been rebuild. I would contact Bow-Tie overdrives for all info, parts or a complete trans. Awesome people and product.
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
#24 |
I got mine for handling the selling of my bosses car, but he paid $1100 for a built 700R4 with a mild converter.
#25 |
MEMBER OF THE JUNK MAN CLUB
im my opinion the 700r4 is the WORST PIECE OF JUNK that g.m. has ever concieved!!!!!!!!
I LIKE 67-72 CHEVYS, I HAVE OWNED OVER 150 OF THEM IN THE LAST 25 YEARS.. ![]() |
