Boxed Frames
i need pics of trucks with boxed frames, mostly need rear shots with a C notched frame for lowering. Also want to see how u ran the brake, fuel lines etc. Thanks in advance!
Happy to be here
![]() Join Date: Mar 2000
Re: Boxed Frames
I don't have a full frame that is boxed, just a C-notch. Maybe one of our resident suspension pro's will have some on file.
![]() Join Date: Aug 2006
Re: Boxed Frames
Here is a pretty trick boxed frame. They ran alot of the brake lines, fuel lines and so on in the frame. Pretty sweet. Here is a link. Near the bottom of the page shows some before pics. http://www.highgearhotrods.com/retro...%20gallery.htm
Josh
(Project truck) 1970 C10 under complete transformation ![]() My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
#4 | |
Tripple Five Fanatic
Re: Boxed Frames
After running the brake and fuel lines then boxing, does the heat from the welder affect the lines? How would you run your electrical if you were to install a new harness? Tri5 |
Re: Boxed Frames
How would you repair a leaking brake line after it's sealed inside the frame rails?
Happy to be here
Re: Boxed Frames
Better make darn sure nothing leaks "before" closing up the frame.
Re: Boxed Frames
How would you know it leaked in the first place?
www.bentcustomandperformance.com |
Re: Boxed Frames
Maybe it's just me, but I like the important things where I can get to them, if needed.
I know everyone likes that "clean & smooth" look, but have you ever had a brake line go bad on your daily driver? Or had to replace a fuel filter that in the line? I think that if you take the time to do a nice, neat (no thumb bends) layout on your lines, the final product is just as nice. And you can work on it too. Burying them in boxed rails would make me extremely cautious if I had to drill a hole or if a line clamp came loose and caused a line to vibrate and rub a hole in itself........ |
Happy to be here
Re: Boxed Frames
If your building a true show vehicle that will be on display, then the time and effort to run the lines inside a boxed frame might be the way to go.
For the more common show and go vehicle routing the lines inside an un-boxed frame hide them quite nicely. If you really want a boxed frame, the can still be routed nicely on the outside of the inner rails and look just a good. Here's a nice example or two from our resident tubing expert-bentfab ![]() ![]()
#10 | |
Re: Boxed Frames
Thanks Man !!!
Re: Boxed Frames
Re: Boxed Frames
Dam...never thought I would be jealous of a pink under carriage.
Re: Boxed Frames
Here is mine
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
Re: Boxed Frames
I think you would loose a brake pedal before you relize your brake fluid is low.
#15 |
Re: Boxed Frames
A slow leak would not necessarily equate to a softer pedal.
#16 |
Re: Boxed Frames
Correct. But when your brake fluid is gone you have no pedal and not knowing when your loosing fluid is the problem. I know because I lost my brakes in my 64 when it still had drums on all 4's. Pushed on the pedal and no brakes !!! Got lucky cause the light changed green right before I got to the signal. Come to find out the front soft line got a hole from age.
www.bentcustomandperformance.com Last edited by bentfab; 03-19-2009 at 12:46 AM. |
#17 |
Re: Boxed Frames
Same thing happen to me in a '65 I had back in high school (wish i still had that one) ... except it was a rear wheel cylinder ... I swear the truck felt like it picked up speed once I hit the woah-pedal!
#18 | |
Happy to be here
Re: Boxed Frames
#19 |
Re: Boxed Frames
You got that right!
#20 |
Commander Taco Bello
Re: Boxed Frames
had that happen on a snowy gravel road in a monte carlo.only had front brakes and couldn't turn at all for the corning that was coming up. went right into the ditch and high centered the car on the snow pack.
luckily it was at a slow speed. damn ford had to pull me out. |
