Old 03-19-2009, 06:16 PM   #1
Hoffman65burb
Hoffman65burb's Avatar
lost lock nut socket
Hey,
my sierra's front tire had a bolt in it, which was holding the air hahaha, till it worn down enough for it to start leaking. Well the tires flat and i cant find my lock nut socket. Anyway to break this off at home? with out torch's / welder?
1978 GMC Jimmy
454bbc
Turbo400
NP205
3.73 gears
4inch lift
33's
Hoffman65burb is offline   Reply With Quote
Old 03-19-2009, 07:00 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: lost lock nut socket
get a 12 point socket that is just a tick too tight, and hammer it on, use a breaker bar to turn it.
Old 03-19-2009, 07:00 PM   #3
JimKshortstep4x4
Two things that I have done is to borrow a wrench from my local yard and lacking the right wrench, I have welded a nut onto the special nut.
Cutting the nut of with a torch is very iffy as it is easy to mesh up the stud,
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-19-2009, 07:11 PM   #4
monte0185
monte0185's Avatar
x2 on this. Most tool companies make a tool for this as well but socket usually works just as good. I usually use a 1/2 inch drive one so i can use my impact.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 03-19-2009, 07:12 PM   #5
El Jay
Gone to greener pastures
You know that one is going into the ol' databank, Andy.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 03-19-2009, 07:15 PM   #6
Hoffman65burb
Would it work for this kind of lock nut?
1978 GMC Jimmy
454bbc
Turbo400
NP205
3.73 gears
4inch lift
33's
Old 03-19-2009, 07:26 PM   #7
mr48chev
mr48chev's Avatar
Been there done that and it works. It isn't too good for the socket though.
The other choice is that tire stores often have the special socket used to drive on and take the nut off.
I'm not sure on that one H but you might get it with a stud puller. There is probably a socket that you can drive over it though either 12 or 8 like that 99th piece in your 99 piece tool set.
Old 03-19-2009, 07:28 PM   #8
Longhorn Man
mine was like this;
I had to do this on my old GMC, truck came with the locks, but no key/adaptor. It worked so good, I just installed them back on the truck.
I would imagine it would work on yours.
Don't use high dollar snap on sockets, but you don't want to use craptastic ones made in china either. I honestly found that the craftsman ones seemed to be good at this task.
Old 03-19-2009, 07:33 PM   #9
bigsnookmaster
bigsnookmaster's Avatar
I've smacked them on the end with a hammer,then put a nice pair of vice grips on them and twisted them off!If you smack it good it will usually loosen them. My .02
bigsnookmaster is offline   Reply With Quote
Old 03-19-2009, 08:01 PM   #10
68 Stepside
huh?
68 Stepside's Avatar
you can also take a junk socket about the right size, tack it on with a welder and take it off, done that before in a pinch.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 03-19-2009, 08:08 PM   #11
stockish shawn
did you try a hammer and chissel.
stockish shawn is offline   Reply With Quote
Old 03-19-2009, 08:13 PM   #12
truckdude239
truckdude239's Avatar
i just hammer on of my impact sockets on it and zip it off with the air gun
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 03-20-2009, 08:41 PM   #13
airdale94
airdale94's Avatar
Those kind are a good candidate for the chisel method. Cut about a 1/4" strait cut into it. In one of those grooves would be a good spot. Then hammer it counter clockwise. A air hammer with a chisel bit is usually about a 5 min. job.
airdale94 is offline   Reply With Quote
Old 03-20-2009, 09:18 PM   #14
BADSAM
J'ville Junkman
BADSAM's Avatar
I would never try this, but I heard an urban legend that back in the day, you could take a can of freon and freeze the nut with it and it would become brittle, then you just hit it with a big hammer and it would break off. Look what happened to the Titanic!
Once again, I would never try this. Just something I heard.
I'm not even sure why I volunteered this info. Must be bored.
(Beating a socket on almost always works for me.)
72 3/4t Suburban 402BB (Daily driver for 8 years)
68 GTO (never ending proj)
91 Kawasaki ZX-7R
57 Chevy 210 Wagon - 9 Passenger (Wife's project-working on floorpans)
73 Corvette (17 yr old daughter's: Another project - what's wrong with me?)
53 Willys M38
BADSAM is offline   Reply With Quote
Old 03-20-2009, 10:04 PM   #15
70 Suburban
Rods
lol well they make a socket for this. its taperd on the inside. they sell them at northern tool and harbor fraight. u just put it on and it will bite down and cut into the nut till there is enough for it to take it off. also there is a tool called a nut splitter that will work here too
70 Suburban is offline   Reply With Quote
Old 03-20-2009, 10:05 PM   #16
70 Suburban
Rods
looking at it you may be able to use a flat head and a hammer to tap it around till its loose enough for vise grips
Old 03-20-2009, 10:26 PM   #17
68C15
blood type; Retumbo
68C15's Avatar
I bought a kit for these a few years ago. it cost like $15 and has like 5 different sized and types of sockets including a tool for locking hub caps. Harbor freight IIRC.
68C15 is offline   Reply With Quote
