I started to remove the rear brake drums so that I can replace the rusty E-brake cables with new stainless. The left side changed out no problem but the right side wheel is locked up & I could not remove the drum.
There is no tension on the old cable as it is fuly disconnected. The pressure line is also disconnected & I have adjusted the adjuster as short as possible. I soaked the edges wear the drum & axle contact with nut buster. My question is how tough is the brake drum? Can I drive it off wih a 2 x 4 or use a three leg puller w/o cracking the drum? Any ideas to remove w/o damage would be appreciated? Thanks |
