Old 04-08-2009, 10:42 PM   #1
bmrrwolfe
1970 C10
gas tank mounting?
I order a under the bed gas tank ebay, it was scratch and dent at a great price.
its an LMC tank but the straps seem wrong?
Also it only came with 2 J mounting hooks?
Are the straps just bent to fit in the box or are they spouse to be bent, and how do i go about mounting this in?
Also they are bent with the mounts opposite.
Thanks!
bmrrwolfe is offline   Reply With Quote
Old 04-08-2009, 11:16 PM   #2
rogergodding
rogergodding's Avatar
Re: gas tank mounting?
same one I have, I made it work....
rogergodding is offline   Reply With Quote
Old 04-08-2009, 11:36 PM   #3
bmrrwolfe
1970 C10
How did you make your straps work?
could i get some closer up pictures of the mounts?
Thanks!
Old 04-09-2009, 09:13 AM   #4
bmrrwolfe
1970 C10
Anyone know??
Old 04-09-2009, 09:59 AM   #5
GOPAPA
GOPAPA's Avatar
Originally Posted by bmrrwolfe View Post
Anyone know??
This is what I did with mine and plan on taking off the two nuts and replacing them with lock nuts..
I used bolts instead of the j-bolts that came with the straps ..hope this helps ya ..papa
GOPAPA is offline   Reply With Quote
Old 04-09-2009, 10:30 AM   #6
bmrrwolfe
1970 C10
Well i bent the straps to be straight and they seem like they will fit well, and i tested the tank and it has two little slots on each side that line up perfectly to holes in the frame.
Now its time to cut the holes in the frame for the mounting strap bolts, any words of advice for this?
