Old 04-14-2009, 06:05 PM   #1
bmrrwolfe
1970 C10
Stripped bolt help!
I'm in the process of cleaning up the motor, and found that the long bolt that holds the alternator in has a stripped head....
whats the best way of getting it out??
i thought about just drilling a small slit and trying to use a large flat head screwdriver to get it out.
whats the best option for me?
bmrrwolfe is offline   Reply With Quote
Old 04-14-2009, 06:16 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Stripped bolt help!
Vice grips, or you could weld a nut to the bolt.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 04-14-2009, 06:17 PM   #3
jamesi20
jamesi20's Avatar
check these out...I got a set at my local sears and they have bailed me out many times http://www.sears.com/shc/s/p_10153_1...2060000P?mv=rr
jamesi20 is offline   Reply With Quote
Old 04-14-2009, 06:19 PM   #4
bmrrwolfe
1970 C10
how do these work?
i may run up to sears to grab a set
Old 04-14-2009, 06:24 PM   #5
cparman
sharp as a marble
cut the head off with a hack saw or a cutoff wheel. slide the alternator out of the way , and put a set of vise grips on the bolt. IF the bolt is not bottomed in the head you should be able to unscrew the bolt.
cparman is offline   Reply With Quote
Old 04-14-2009, 06:35 PM   #6
El Jay
Gone to greener pastures
If this doesn't work, heat the bolt good-n-hot with a propane torch & then hit it with a candle right next to the head. The wax will suck in and lubricate the threads.
Then try to back the bolt out again.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 04-14-2009, 07:30 PM   #7
truckdude239
truckdude239's Avatar
i have a set of snap on ones you jsut trap on the right size one and take a wrench and turn it out like normal
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 04-14-2009, 07:49 PM   #8
berencam
berencam's Avatar
i usually grind two flat spots on either side of a damaged bolt head, then just use either a crescent wrench or a vice grip ad winch it off.
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
Old 04-14-2009, 08:04 PM   #9
bmrrwolfe
1970 C10
It expanded nicely and was stuck around the alternator itself, i just ended up using a cut off wheel and cutting it right past the alternator.
Thanks for the help!
