Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 04-16-2009, 11:30 AM   #1
5150
C10 Club Tennessee
5150's Avatar
amp problem
I have two amps in my blazer. They both have separate ground wires, but share the same power wire that runs to the battery.
The smaller amp keeps going on and off, on and off, on and off, and I don't get any sound or anything from the bigger amp. Sounds like a heartbeat coming out of the speakers. Speakers that aren't even hooked up to that amp.
Everything was fine with the bigger amp and its 4 speakers until I hooked up the smaller sub amp.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 04-17-2009, 03:00 AM   #2
AceX
>130dB Moderator
AceX's Avatar
Re: amp problem
Sorry, I tried to reply earlier and my computer died.
The amp is going into protect, and from what I gather, probably due to low voltage.
Try running a seperate power wire and fuse to the sub amp, or run a larger (4ga) main line then a distro block to split a 4ga wire into twin 8ga wires.
While you're at it, double check your grounds and all that.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 04-17-2009, 09:18 PM   #3
Riveted1
Tasty Cakes!
Riveted1's Avatar
Re: amp problem
Also, make sure none of your speaker cables are in contact with metal OR one another!
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 04-18-2009, 01:51 AM   #4
AceX
>130dB Moderator
AceX's Avatar
Re: amp problem
Dam, right as I saw this thread again, I was gonna say double check all the speaker wire for a short as well.
Beat me to it...
Again, just double check ALL of your connections. 99% of the time, it's a loose or crossed wire...
Living Life @ 130dB
RIP El Jay
Old 04-18-2009, 09:11 AM   #5
5150
C10 Club Tennessee
5150's Avatar
Re: amp problem
Double checked and Double Checked. Borrowed another amp from a buddy and it works fine. So something's up with the amp.
Got the seat back down and the speaker box installed. Check out my build thread for the pics. I think it looks pretty decent.
Bryan
www.gmtruckshow.com
