Old 04-10-2009, 01:03 AM   #1
Rogue_Sentinel
Rogue_Sentinel's Avatar
ram air ?
do they make a ram air kit for a 79 c10 ? if so were can i find one at ?
"Myths and legends die hard in America. We love them for the extra dimension they provide, the illusion of near-infinite possibility to erase the narrow confines of most men's reality. Weird heroes and mould-breaking champions exist as living proof to those who need it that the tyranny of 'the rat race' is not yet final."
Hunter S THompson
Rogue_Sentinel is offline   Reply With Quote
Old 04-10-2009, 01:06 AM   #2
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
Re: ram air ?
ramairbox.com
An inexpensive one.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 04-14-2009, 10:27 PM   #3
pig rig
pig rig's Avatar
Re: ram air ?
I made mine its an 88 crew cab and yes thats 4" pipe
on the 81-91 core support they have 4" holes on each side of the radiator. I went and looked at a 70 somethings core support and it looks like you could blow a hole in it.
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 04-15-2009, 03:16 PM   #4
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: ram air ?
Slick set up do you have a small filter in the Plenum on top of the carb
Malo83 is offline   Reply With Quote
Old 04-14-2009, 10:46 PM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: ram air ?
I'm the first as far as I know to adapt a ram air box to a 88-91 grill setup.
I use a 81-82 bumper as the inlet.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 04-15-2009, 01:30 AM   #6
Rogue_Sentinel
Re: ram air ?
where do you guys buy your air box ?
my c10 has 1 hole on one side of the radiator the other is cover .
Hunter S THompson
Old 04-15-2009, 08:40 AM   #7
JohnC
JohnC's Avatar
Re: ram air ?
Look at Philatruck's post. It is a pretty inexpensive route, and it looks good too!
JohnC is offline   Reply With Quote
Old 04-15-2009, 09:55 AM   #8
Cherub
Cherub's Avatar
Re: ram air ?
the other side can be knocked out also.
Cherub is offline   Reply With Quote
Old 04-15-2009, 10:40 AM   #9
jdurant
Re: ram air ?
Mine have had holes on both sides. I've cut/ or removed the cover from the front part on the factory setup and the baffle in the air cleaner in the past. Technically, that is ram air--and nothing is cheaper.
gchemist--I likey.
Joseph
87 Turbo Buick
92 5.0 Mustang coupe
87 GMC Sierra SWB
82 Chevy K5 Blazer 2wd
jdurant is offline   Reply With Quote
Old 04-16-2009, 09:07 PM   #10
gchemist
gchemist's Avatar
Re: ram air ?
Originally Posted by jdurant View Post
gchemist--I likey.
Wait until you see it in person. Texas needs a gathering!!
Old 04-15-2009, 10:48 AM   #11
69BBsuburban
Right in front of you.
69BBsuburban's Avatar
Re: ram air ?
My truck has the RamAir air cleaner box....the ducting and mounts at the core support are from the local hardware store. Dryer ducting.
69BBsuburban is offline   Reply With Quote
Old 04-15-2009, 10:52 AM   #12
JohnC
JohnC's Avatar
Re: ram air ?
Always support your local Hardware Store! Sorry it's a shameless plug for me being a local hardware store manager!
Old 04-15-2009, 10:57 AM   #13
69BBsuburban
Re: ram air ?
Hell yeah....I'm in my local Ace at least once a week, support local businesses.....doesn't hurt that there is a liquor store INSIDE....
Old 04-15-2009, 04:36 PM   #14
JohnC
JohnC's Avatar
Re: ram air ?
I guess I better get on the ball. "Note to Self" remove plumbing section, and install Liquor Store.
Old 04-15-2009, 04:53 PM   #15
pig rig
pig rig's Avatar
Re: ram air ?
malo83 yes that has a filter in it there I'M thinking about reenginering it
Old 04-17-2009, 01:35 AM   #16
72lb4x4
Re: ram air ?
It may look nice, but I've always thought that actual power from this was something of a myth.
Not just the ram part (insinuating that there's some sort of turbo effect) but the colder outside air on a street engine won't produce a noticeable difference in power.
I'm not much for adding things that could fall off w/o a real advantage. Then again, mine's a 4x4, so not much can help in performance.
Any thoughts?
72lb4x4 is offline   Reply With Quote
Old 04-17-2009, 08:25 PM   #17
PhilaTruck
PhilaTruck's Avatar
Re: ram air ?
Who said I'm running a street engine? Okay, just kidding.
The ram effect only happens at inconveniently high speeds, but the increased density of colder air, the increased mass of a given volume, increases engine output.
If you want proof, look a drag times at high altitude.
Heck, I noticed a difference in higher RPM power when I flipped air box lid.
Subscribe here!
