Old 04-18-2009, 09:11 PM   #1
13lazer
13lazers' blazers
13lazer's Avatar
My gas tank is cracked?
Does anyone have some advice on how i can repair my cracked gas tank. Its a 1985 suburban, and it looks like i hit a rock or something. The tank is dripping gas fairly quickly. I want to use some gas proof epoxy. I'd like to not have to drop the tank. Obviously i can't braze it without dropping it.
Any advice would be appreciated.
1970 2wd blazer
1972 1ton blazer 4x4 in progress
1966 mustang coupe (modified)
1985 c20 suburban tow rig
1996 462 ranger with a 150 efi merc. a former B.A.S.S. tournament boat
almost all exempt from california smog laws intentionally.
13lazer is offline   Reply With Quote
Old 04-18-2009, 09:20 PM   #2
slash crashley
lucky knuckles
slash crashley's Avatar
Lightbulb
i've heard of using jb weld in a pinch as a temp fix. also i remember a few years back a product used to fix splits in petroleum tanks... ack, i can't remember it for the life of me. it was pliable like plasticine and then hardened.
slash crashley is offline   Reply With Quote
Old 04-18-2009, 09:40 PM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: My gas tank is cracked?
any of those kind of products dont last the best thing to do is either pull the tank and repair it or swap it out
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 04-18-2009, 09:50 PM   #4
silvereagle07
silvereagle07's Avatar
Like old rusty said, swap it out new or used. Products like JB Weld won't last.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 04-18-2009, 10:47 PM   #5
3r!c84
Badass
3r!c84's Avatar
empty the tank and sand down where the hole is and jb weld it up it will last ,idk how long?
worked on my 84 atc gas tank never had a problem
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 04-18-2009, 11:29 PM   #6
13lazer
13lazers' blazers
13lazer's Avatar
thanks guys, the jb weld idea is what im looking for right now. i just wasn't sure if the gas would break down the epoxy. i'll swap it out when i can, but right now its my daily driver.
1970 2wd blazer
Old 04-19-2009, 01:57 AM   #7
pig rig
pig rig's Avatar
the gas will eat the JB weld it will work for a day or two
I had a tank with a pin hole in it that was discovered on a trip cross country. and over the week and half that I was gone I probly spent $200 on temp fixes for a $100 tank
so my advise is put a new tank in it and be done with it
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 04-19-2009, 02:22 AM   #8
Tantrix
Either pull it and get it welded, or order a new tank. I got a brand new 20 gal fuel tank and sending unit for my '76 C10 from RockAuto for $157.66 shipped to my door. I pulled 2 tanks from other trucks but found they were about to rust through and start leaking too. If you go look for an old one to pull, be sure to inspect it well because they are notorious for rusting through.
Tantrix is offline   Reply With Quote
Old 04-19-2009, 03:23 AM   #9
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
Gas won't break down epoxy. I would use that as a stop-gap and fix it the right way later. Don't mess with leaking fuel.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 04-19-2009, 05:52 AM   #10
billnorman
Gas or gas fumes love sparks. That said, I repaired a lot of tanks by removing and draining them, running water through them for a couple of hours, draining them, putting the rusty area upward, and grinding the holy area down with a 9 inch 80 grit sander. The object is to remove the rust, but as little of the metal as possible. Then mix up some Bondo or other hockypuck filler, and repair the area, forcing the filler through the holes. By the time you get it back in it should have cured. I have had great success with this method, but if you blow yourself up, don't come running to me when you get out of rehab.
billnorman is offline   Reply With Quote
Old 04-19-2009, 07:09 AM   #11
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
13lazer: I'm LAFD retired. Go over to Fire Station 48 in San Pedro. They have a Haz-Mat squad and ask them what they use to seal a leaking gas tank.
78 Big10 454 is offline   Reply With Quote
Old 04-19-2009, 08:58 AM   #12
oldgmc
oldgmc's Avatar
In my local NAPA the have a product on the rack that is to repair leaking tanks I forget the maker maybe permatex of 3m.
Never used it but if I were to try a patch I would use one that is advertised for the repair.
However I would consider any patch a temp and put in a new tank when time allows,
oldgmc is offline   Reply With Quote
Old 04-20-2009, 08:22 PM   #13
PhilaTruck
PhilaTruck's Avatar
Now that was funny!
Subscribe here!
Old 04-21-2009, 09:34 AM   #14
454HO
JB Weld should work fine as a temporary fix. I can't recall how many times I have seen it recommended to seal the well plugs on Q-Jet carbs.
Look at the number one usage for autos on their web page -
AUTOS, MOTORCYCLES, MECHANICAL
fuel tanks
radiators
cracked engine blocks
transmission & rear-end casings
cylinder heads & sleeves
generators, starters, water & fuel pumps
axles & hubs
valve guides
press fit bearings
crankshaft pulleys
casting defects
door stops
key ways
stripped threads
body shop repairs
And read their product description page -
Mechanics -- you can use J-B WELD with confidence. It is designed for safe, reliable, permanent repairs in engine compartments and heated environments up to 500° F. It's strong as steel and impervious to water, gasoline, chemicals, and acids. Working with J-B WELD is quick, easy, and convenient -- and saves you time, work, and money!
- Greg
454HO is offline   Reply With Quote
