Old 04-22-2009, 02:45 AM   #1
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
Unhappy carb w/o break bost line? Help!
so, I found a carb on criags list. went out there and it looked really, really good. best one Ive seen so far. so I take it home, take off my old carb and notice that the "new" carb does not have the hole to screw in my break line! so, will it run with out that hooked on? what will happen if the brake line isn't hooked up? I do have a Rochester carb *just like the "new" carb, just newer in age* that has the throttle plate that has the brake line but I don't think the bushings are good. is it possible to drill/tap in the "new" carb to make it work? or a way to hook up some other line to make the power brakes work? Thank y'all! Matt
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 04-22-2009, 02:54 AM   #2
Manbearpig
Manbearpig's Avatar
Re: carb w/o break bost line? Help!
It will run fine without it hooked and you won't have power brakes.
You could probably swap your throttle body off your "older" carb to the one you bought and that will solve your problem
No need to drill anything
1972 GMC C10
Manbearpig is offline   Reply With Quote
Old 04-22-2009, 03:16 AM   #3
78 Chevyrado
Just hook it up to the intake manifold somewhere. it'll work just as good. I wouldn't drill into your new carb, or you may end up with brand new junk. They do make spacers with the hole in it.
78 Chevyrado is offline   Reply With Quote
Old 04-22-2009, 04:50 AM   #4
79gmcc15
79gmcc15's Avatar
wow very fast reply's guys, thanks! I will look into switching out the plates and looking for the spacer. the carb is from a early 70's. so I noticed it doesn't have as many vacuum ports on the plate. so I might have to cut out some of the non important stuff.
RIP ELJAY
Old 04-22-2009, 04:55 AM   #5
Manbearpig
Manbearpig's Avatar
Just use your old plate
Save a buncha hassle
1972 GMC C10
