Old 04-23-2009, 09:59 AM   #1
VanceH
Loving the Jimmster
VanceH's Avatar
Who in the HECK designed this darn thing??
I am taking out my motor, i am trying to get the ramshorn off. Who in there right mind would have put two threaded bolts from the bottom up?? This makes no sense to me. When i put this back together is there a better set up for the connection between the rams horn and the exhaust pipe?
VanceH is offline   Reply With Quote
Old 04-23-2009, 10:20 AM   #2
cruiserman
Re: Who in the HECK designed this darn thing??
Threaded studs with nuts?
72 C2500 LWB 402 Sierra Grande
05 Odyssey
08 Tundra
cruiserman is offline   Reply With Quote
Old 04-23-2009, 10:42 AM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
That's what mine have...
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 04-23-2009, 10:56 AM   #4
VanceH
Loving the Jimmster
VanceH's Avatar
Ya one is solid and connected to the rams horn, the other two are long bolts that thread up thru the rams horn and then have a nut. Seems like over kill to me. It wouldn't be so bad if the rams horn wasn't threaded. Can a guy drill out the threads?
Old 04-23-2009, 11:05 AM   #5
leddzepp
Moderator
leddzepp's Avatar
you can drill them and and fix it with an oversized helicoil.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 04-23-2009, 11:09 AM   #6
VanceH
Loving the Jimmster
VanceH's Avatar
What about drilling them and leaving them smooth? So the bolt will just slide up and then use a nut and lock washer? It took forever to crawl under there and un-thread them once i had the nut off.
Old 04-23-2009, 11:24 AM   #7
leddzepp
Moderator
leddzepp's Avatar
Sounds like a good idea. I do not see why it would it would not work.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 04-23-2009, 05:57 PM   #8
425HP409
425hp409
425HP409's Avatar
Originally the exhaust manifolds had three studs threaded into them, and the exhaust pipes connected up to them with the flange, and three nuts from the bottom. This enables you to take the exhaust pipes off of the manifolds without having to hold a nut and a bolt. I always use extra long brass nuts available at all auto parts stores from the bottom so they will come off easily. If someone put bolts through the manifolds, it is because the threads are no good. I would install Helicoils or Thread Inserts and go back with the original type studs and nuts.
425HP409 is offline   Reply With Quote
Old 04-23-2009, 06:08 PM   #9
Lugnut64052
Middle-aged Curmudgeon
Lugnut64052's Avatar
I think that'll work on most of the holes, however I believe there's one or two where the manifold twists into the way, not leaving enough room on the top of the flange.
Bret
Check out the site's Truck Tech FAQ.
Be a site supporter.
My more-or-less pathetic build thread.
Board members I've met:
Longhorn Man
Dieselwrencher
jholley
big mike71
Lugnut64052 is offline   Reply With Quote
Old 04-23-2009, 06:09 PM   #10
Lugnut64052
X2
Bret
Longhorn Man
Dieselwrencher
jholley
big mike71
