Old 04-19-2009, 10:30 PM   #1
Rudy67chevy
rudy67chevy
Rudy67chevy's Avatar
02 silverado hard to start when warm
my 02 silverado is hard to start when i park it. for a few minutes or hours after i drove it. A few block or a few miles. The truck acts like my old chevy, when i try to start it in the morning
Rudy67chevy is offline   Reply With Quote
Old 04-21-2009, 01:12 PM   #2
Slammed67
Progress = 0%
Slammed67's Avatar
Re: 02 silverado hard to start when warm
Have you checked the fuel pressure regulator? My truck had a similar issue and that was the problem. It's located on the driver's side of the engine and has a vacuum hose hooked to it. Pull off the hose (with the engine off) and if any gas drips out, it needs to be replaced. Just a thought and is easy to test.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 04-21-2009, 01:18 PM   #3
skidder111
skidder111's Avatar
Mine did that when it was fairly new; started OK when cold but not when warm. Turned out it was faulty injectors causing flooding. Just a thought.
skidder111 is offline   Reply With Quote
Old 04-21-2009, 06:50 PM   #4
jkade
jkade's Avatar
Exact same thing happend to my 02. Replaced the regulator and it never missed another beat.
jkade is offline   Reply With Quote
Old 04-25-2009, 03:33 PM   #5
dmarty
Active Member
dmarty's Avatar
I had the same problem. See my earlier post. It was the press reg. Put a fuel press gauge on it and see what the press is. I just pressed in the Schrader valve on the fuel rail and nothing sprayed out. I'm not sure, so you better check with the manual, but I think the press should be about 60 psi. Also, when I pulled the vacuum line, gas ran out. Replaced the press reg and it has been running fine now for 2 months.
72 GMC Sierra Grande SWB 402 BB A/C
(Owned it since 1973)
99 Silverado 1500 LT with 315K miles
(RIP)
2012 GMC Sierra SLT
dmarty is offline   Reply With Quote
