Old 05-08-2009, 02:00 PM   #1
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
ATF, ATF everywhere
Alright guys and gals, I've got a bit of a conundrum.
I put the 87 together about 6 months ago, but still haven't plated it for the the street. The trans (TH350, which was built new about 5 blocks away) has been rebuilt and has about 15 miles on it.
Here's what is happening. I put the trans pan on, and everything is fine. No leaks at all. I can go for a drive, and still no leaks. I can let the truck sit overnight, start it up, drive it, no leaks. but then after 2-3 days of the truck sitting, BAM, 3 quarts of ATF on my nice clean driveway. At first I thought the pan was the culprit, so I bought an aluminum pan that would not distort when i put the bolts in. I thought that fixed it until 3 days later there it was leaking again.
I can't really see where the hell it's leaking from... other than the pan area itself. my cooling lines appear to be tight.
Ideas?
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 05-08-2009, 02:11 PM   #2
Jonboy
Slots go on anything!
Re: ATF, ATF everywhere
It's probably the dipstick tube. The older ones just have an O-ring seal, and are prone to bending. The newer ones have a locking dipstick, and use a boot type seal at the case. The problem you are most likely having is the fluid draining out of the converter when it is setting. That raises the fluid level in the pan above the dipstick seal, and it leaks. The new tube, seal, and dipstick is less than $30 at the dealer.
Jonboy is offline   Reply With Quote
Old 05-08-2009, 02:23 PM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I was able to get the seal for my dipstick at NAPA.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 05-08-2009, 04:29 PM   #4
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Lightbulb Re: ATF, ATF everywhere
Have you spoke to the shop that built it and see what they say it might be?
The dip stick sound's like a good place to start tho ya may wanna look at the oring on the vac mod as well.
good luck
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 05-08-2009, 04:48 PM   #5
smashingchuck
Alright guys... I'll be getting a new dipstick. Any recommendations? I want to fix this problem for good, so if there is a better one out there, I'm all for it. Right now it's got an el-cheapo chrome one.
78 Build Thread
4Runner Build
Old 05-08-2009, 05:54 PM   #6
Jonboy
The cheap chrome one woul dbe my guess. You can try the boot seal on it to see if it will fix it. I had the same problem with my 75 Blazer after putting a rebuilt trans in. Replacing the tube, stick, and seal worked for me.
Old 05-08-2009, 06:04 PM   #7
3r!c84
Badass
3r!c84's Avatar
the shifter seall..mine has the same problem..have not changed it out yet.you have to drop the pan and pull out the shifter rod and slid in the new seal..but mine is only a few drops a day not no 3qts
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 05-08-2009, 07:58 PM   #8
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
you did say its a 350 so another spot to check it the kick down cable.some have o rings some have a seal either will leak
powerdriver 1958 is offline   Reply With Quote
Old 05-08-2009, 09:30 PM   #9
bagged74
its just $$$$$
bagged74's Avatar
this is my guess as well
bagged74 is offline   Reply With Quote
