Old 05-20-2009, 05:49 PM   #1
Chlsnk
Chlsnk's Avatar
Unhappy Well my rearend blew out (I think)
Well after I got out of school today I took my truck around my circle drive to move it into the garage to start welding on my patch pannels and I hear CLA- CLUNK and my engine rapps out. Im in the street at this point I hop out thinking oh no my tranny hopped out of gear. I see behind me a big puddle of antifreeze I crawl under it to see if mabey my linkage poped off from the tranny or something , nope it's all good. I burn my wrist on my header and looking back I see my drive shaft spinning freely . This is when I figure the rearend shelled. I add a bunch of water to my radiator and let it cool down for awhile. I come back out ten mins later and start it back up running it through the gears ......nothing! it won't move. I called my neighbor and they helped me push it back into the driveway.
How much work is it and is it worth it to try to find a F*RD 9 inch?
So it looks like i'll be on craigslist looking for a new rearend for under $100 or try to sell my guitars for some more cash to avoid having to try to get my parents to loan me any money. Looks like it may be sitting for a few weeks until my summer job starts.
Chlsnk is offline   Reply With Quote
Old 05-21-2009, 03:08 PM   #2
truckincurt
Re: Well my rearend blew out (I think)
the onley good thing about a f*rd 9 in is that you can swap gears easly if you dont plan on doin that you can just run like a chevy 12 bolt or if your bulidin alot of power 14 bolt
truckincurt is offline   Reply With Quote
Old 05-21-2009, 03:57 PM   #3
Pyrotechnic
Pyrotechnic's Avatar
You should be able to find a rear end for next to nothing. Plenty of 10 bolt open 2.73 and 3.08 out there that will bolt in and get you down the road.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 05-21-2009, 04:38 PM   #4
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
I picked up a stock 12 bolt for $75 off a guy here local parting a Burban. Look for one of them. There is almost always some out in this area if you can't seem to find one near you. Road trips are fun, you know?
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 05-22-2009, 06:50 AM   #5
Chlsnk
Chlsnk's Avatar
Driveway dreams will the 12 bolt match right up? Is it the 5on5 lug pattern aswell? Im just trying to keep it cheep on my highschool kid budget.
Old 05-22-2009, 08:20 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Any 73-87 2wd truck (73-82 Blazer)will work. You can look for 73-91 2wd Burbs as well.
Search your local Craigslist for Suburbans. They seem to be the most common that are being parted out.
Here is one- LINK
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-22-2009, 10:52 AM   #7
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
If you swap your 5 lug axles and drums (put your old ones in the replacement housing), you can use one from a 4x4 too. You have to be a little more selective then and use a 10 bolt if thats what you already have or a 12 bolt if that's what you have. Also, if you have a 10 bolt, the 88 and up will have a different axle spline count than what you have.
You have lots of options and should easily be able to get a replacement rear end for $100 or less.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
Old 05-23-2009, 04:45 PM   #8
Chlsnk
Chlsnk's Avatar
So 10 bolt axels and drums will fit a 12 bolt? Not quite aure what you were trying to say.
Old 05-25-2009, 06:46 PM   #9
ElGracho
ElGracho's Avatar
No.
10 bolt 5 lug axles are interchangable with 10 bolt 6 lug axles through 87.
12 bolt 5 lug axles are interchangable with 12 bolt 6 lug axles.
The drums themselves are interchangeable between bolt patterns on both axles (for the same size brakes...)
Joe
Old 05-25-2009, 07:56 PM   #10
Chlsnk
Chlsnk's Avatar
It's the spider gears.
Old 05-25-2009, 08:18 PM   #11
williej45
williej45's Avatar
A friend of mine had that exact thing happen last month. Got gears and cross shaft from a bone yard for $25.
Rule #1: If it's stupid but works, it's not stupid.
williej45 is offline   Reply With Quote
Old 05-31-2009, 09:58 AM   #12
Chlsnk
Chlsnk's Avatar
Well I have a 12 bolt 5 lug rearend and a steering column being delievered to my house today . I found a guy who will trade me them for some impala tail lights I have.
The truck was a heavy half so did it just have a beefed up suspension to get that designation?
Old 05-31-2009, 10:13 AM   #13
Pyrotechnic
Heavy Half was more than just suspension. There's a thread here outlining it but in short it was 3/4 ton springs, larger rear breaks, larger brake booster, 2 piece drive shaft, extra frame crossmembers, double hump transmission crossmember, very little if any emissions equipment and an increased gross vehicle weight rating.
If that rear is really is from a heavy half, it will have the wider rear brakes. Something to also note is that most heavy half trucks also had an upgraded rear end gear, numerically higher than the usual 2.73 or 3.08. No telling whats in it but you might get lucky.
Old 05-31-2009, 10:46 AM   #14
Chlsnk
Chlsnk's Avatar
Well that is good to know!
Old 05-31-2009, 12:54 PM   #15
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
for whatever reason i know of a bunch of guys who have these kind of gears blow... astro vans are notorious for them blowing.... My buddy who is good at this kind of stuff was able to find a whole list of cars and trucks that have the same type of gears so he could pull the gears out of those rears *it was an astro van and any 10 bolt gm will work i think) and always had a couple of sets laying around
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is online now   Reply With Quote
Old 05-31-2009, 02:01 PM   #16
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by old Rusty C10 View Post
for whatever reason i know of a bunch of guys who have these kind of gears blow... ...
Could it have been....
Articles-
"Refining Sierra"
Old 05-31-2009, 02:06 PM   #17
Chlsnk
Chlsnk's Avatar
I think doing a few to many burn outs may have attributed to the faliure of my rear end.
Old 05-31-2009, 07:57 PM   #18
old Rusty C10
the guy im referring to with the astro van used it for work and was kinda hard on it..
Bob
I hate cancer!!
