Old 06-03-2009, 11:30 PM   #1
dlanders
dlanders's Avatar
Brake Hose Question
I had some flexible stainless steel brake hoses made at my local BrakeQuip dealer a few weeks ago. When I went to put them on over the weekend I noticed that I have a small leak where they bolt at the caliper. I just figured I needed some new washers so I picked up the only copper ones that I could find at the parts store. They didnt work so I picked up some brass ones at lowes that had a smaller hole. They dont leak as bad as the first ones but nonetheless they still leak. My next choice was gonna be some kind of nylon/plastic washer. The dude at Brakequip says the copper ones should work fine but I cant seem to get it to work. Has anyone had this problem or have an idea of something I could do?
dlanders is offline   Reply With Quote
Old 06-04-2009, 08:07 AM   #2
James McClure
One shot, one kill.
Re: Brake Hose Question
You may have put the hose ends onto the caliper upside down, they only go on one way. The side with a raised area where they mate to the caliper should be away from the mounting point and is where the attaching bolt head should be. I've made this mistake myself even though I worked for Chevy for 33 years. Hope this helps, jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 06-04-2009, 11:25 PM   #3
85Bowtie
85Bowtie's Avatar
I don't think copper and brakes should be in the same sentence. You never use copper when dealing with brakes, it's what destroys your fluid among other things.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip
'68 Plymouth Road Runner 383, 727, 3.23 Sure Grip
'89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip
'77 Dodge Monaco ex cop car 440, 727, 2.71
'79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip
'12 Dodge Challenger SRT8 392, M6, 3.92
'85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73
85Bowtie is offline   Reply With Quote
Old 06-05-2009, 01:27 AM   #4
dlanders
dlanders's Avatar
That is good to know. I had no idea. So will a nylon/plastic type washer work and seal properly? This is what the end of the hose that attaches to the caliper looks like. The guy that made them said they should work fine. Sorry the picture is fuzzy. I can take pics of the actual hose tomorrow if need be.
Old 06-05-2009, 04:29 AM   #5
heavychevy79
Cheyenne Super
heavychevy79's Avatar
Copper washers are used all the time for those fittings.
I've never heard of nylon washers being used for that, and I wouldn't try it.
I think you have an interferance issue where it bolts/clamps to the caliper.
You may need to do some grinding.
heavychevy79 is offline   Reply With Quote
Old 06-05-2009, 06:03 AM   #6
James McClure
One shot, one kill.
I was a mechanic for Chevy for over 30 years and copper is ALL they use for the caliper/line gasket and upper bolt seal. Don't use anything else!! Any plastic is going to blow out, aluminum will corrode, and forget any fibre material. Did you use 2 gaskets on the bolt? There should be 2, one on top(at the bolt head) and one below (between the hose and caliper) jim
Old 06-05-2009, 06:20 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Check the mating surfaces on the hose fitting for burrs. You might need to take a file and surface it a bit to make sure it is flat for the washers to bear against.
Use only copper crush washers. There is not a car made with plastic banjo bolt washers used in the brakes and there is a reason why. You simply cannot risk a plastic or fibre washer failing in this application. Copper only.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 06-05-2009, 09:51 AM   #8
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
every caliper ive ever seen has copper washers between the caliper and hose
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 06-05-2009, 09:59 AM   #9
Tony@AirRideTech
Junior Member
Copper........ no Nylon or poly, it wont hold up to the heat generated at the caliper. If you go to an autoparts store grap some extras, if one doesnt get it, remove it and put another one on. It is not uncommon for it to leak if you are trying to reuse an old washer.
Tony@AirRideTech is offline   Reply With Quote
Old 06-05-2009, 07:45 PM   #10
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Look for a bent / cracked bolt.............being as your are using after market stuff look for the way they fit.not binding on something and a grain of anything sand or dirt and you will have probs
Oh while your at it,Put me in the COPPER WASHERS ONLY crowd
powerdriver 1958 is offline   Reply With Quote
Old 06-06-2009, 07:42 AM   #11
Desert1957
Desert1957's Avatar
"Ditto"......Me Too
Desert
Desert1957 is offline   Reply With Quote
Old 06-06-2009, 07:57 PM   #12
dlanders
dlanders's Avatar
Thanks for all the help and info guys. I cleaned everything up and I replaced the banjo bolts and put on new bleeder screws and new copper washers and that fixed it right up. I also got my flat fixed and took 'er and the wife out for a little cruise last night. I really wanted to be at the Super Chevy show this weekend but I have finals for the next 2 weeks.
Old 06-06-2009, 09:27 PM   #13
Trimman
Trimman's Avatar
Mableton I was born & raised in Powder Springs! Small world!
82 C-10 Scottsdale LB owned since 89
350 crate vortec heads Crane 1.6 full rollers
edelbrock 1406
edelbrock performer eps intake
dynomax headers/flowmaster 70's
BTO 700r4 level 3
custom 2 piece driveshaft
12 bolt gov loc w/3.08
Trimman is offline   Reply With Quote
