Grandpa in the rustmobile...
does $50 sound good for a 5 lug coil spring rearend? neighbor has one i need to finish my 5 lug conversion..he wants 100 but thats too high to me lol, ima offer him 50 bucks cash and havent figured how ima drag it 1/8 mile across my field to my house lol
can i post wiw if someobdy else is selling it, if not please delete this
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Re: does $50 sound good for a 5 lug coil spring rearend?
A 5-lug coil sprung rear in a one wheel wonder is worth $100-150 so if you steal it for $50 more power to ya!! It may be a posi, and if so then it is worth $300 or more depending on the ratio. Redneck it, stick it in the trunk of a car it is only 1/8, or get a couple of "BIG" friends to come over and carry it for ya!! Buy beverages, they'll do it, I would!
lol beverages are out lol
its far nuff away to shoot it with a pellet gun lol its gota swb bed on it too, bed is SHOT though...has 2 good steel wheels also its been sittin awhile, should i have to rebuild anything on it?? bearings brakes anything, id like ot be a plug'n play thingn..
the pollock
anything with rubber on it
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
I would pull the cover and change gear oil and inspect it to be sure no broken teeth or metal chunks in the carrier (this also allows you to ID if it is a posi or not!), also do a rear brake job, $50 and you won't have to worry about them for a while!!
It probably needs new seals all around. Hopefully no water got in it.
I'd jump on it for $50.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! ![]() 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! ![]() |
I'd be willing to bet the ring gear is rusty.
I've seen rears that sat a long time... where anything above the level of the oil becomes rusty from condensation. I'd pull the cover and check it before handing over any cashmola. |
ENGINE BUILDER
Sounds like a good deal.
JIM ZAG |
well its in some briars...if the ring gears rusty...will it have to be replaced, if yet im backing away...
Well yes and no, if the rust has made pits, then yeah because that'll weaken the teeth, but again for a $50 rear, I'd still buy it and run it rust or not, clean it up real good and use, just know somewhere down the line you'll need a set of gears ($150-200) and the labor to have it installed (another $200 or so), but untill then you have a 5-lug rear.
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Any idea what year rear end it is? You may be able to swap the axles into your 6 lug axle? Someone correct me if im wrong ...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
motor exploder
71/72 5 lug axles will be too long if it's a pre-71 6 lug rear.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
well i know its 71 72 chevy rearend lol...may try to talk to him today..man my summer is busy....
work on truck, eat sleep, wake up geton here, find nother part/thing to do wokr on truck....eat....see gf, ride the wheeler, go bed, wake up play on truck find parts money to fix it cause i shorted something out...etc etc
#15 | |
#16 |
Value would be based on condition,which we know nothing about.But,if the guy is willing to cut his price in half for you because you don`t have as much as he wants and the rear is something you can slap in and run,then yes it`s worth it.
#17 |
If it was my neighbor I would have given him the $100 already.
#18 |
i can buy a whole swb truck for 700 lol
ima try to find him today and offer 50$ so i can have another LITTLE project...
#19 |
I can't pick one up at a salvage yard around here for less than $500. with 373's
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" ![]() |
