![]() Join Date: Apr 2008
front end help
have 68 3/4 ton longbed, switch to 71 72 disc brakes . problem drivers tire
1/4in from hitting sway bar. when turning to the right. turn to the left pass tire is 4in from the sway bar. and turning it drags the tires.. second problem in lots of sway in the the front end at speeds of 50 and higher. had the front end align. please help |
Re: front end help
Sounds like one problem may be that the steering box might have not be centered from lock to lock before the pitman arm was attached.
Also, was this a 3/4 to 3/4 or to 1/2 ton? |
Re: front end help
3/4 drum to 3/4 disc. we centered the pitman arm, still have the problem. any other ideas
Re: front end help
I know you said it was aligned but the only other thing I can think of is that maybe the springs aren't properly seated.
