Old 06-29-2009, 07:55 PM   #1
BP68
BP68's Avatar
Opinions On Tach install
Hey all. I am planning on modding my cluster a little. I dream of a No Limit billet cluster full of Auto Meter Carbon Fiber gauges, but that 800.00 is better spent toward paint and body work right now.
In the mean time, I would like to mod the good cluster I have.
I plan to do like (I think it was Gringoloco) and mod a sunpro volt gauge by adding its guts to the stock face plate.
Here are my question: My truck is med to dark blue and will have charcoal interior.
1. Should I go with white face decals or carbon fiber ones for this cluster build?
2. Should I just mount my Sunpro tach from the front, or try to make it work from behind?
Thanks for your comments and opinions. Please feel free to post some of your modified clusters. Thanks
Here is my dream cluster except no memory tach, and with carbon fiber gauges.
Here are some mock ups mounted thru front.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 06-29-2009, 07:57 PM   #2
BP68
BP68's Avatar
Re: Opinions On Tach install
Here are the ones from behind if I can make it work.
03 Grand Prix GTP
Old 07-06-2009, 01:25 PM   #3
BP68
BP68's Avatar
ttt
Opinions? Anyone ?
03 Grand Prix GTP
Old 07-06-2009, 01:46 PM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
If you are using the stock gauges in the new face, I think figuring out how to get the tach behind the face would be better looking then mounting from the front. That is if you can get it to mount from behind.
As for color, are you going to change the tach as well or will it be as shown? If as shown, I would do whatever makes them look the same. White faced gauges with a black faced tach will look very "add-on" and not blend like it was meant to be there.
My .02 worth.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-06-2009, 04:14 PM   #5
BossHogg69
motor exploder
BossHogg69's Avatar
I like the way the tach looks behind the lens, and with the all black factory gauges, looks much cleaner to me.
Like you, my dream setup is the billet dash piece with Autometers, but I didn't have $800 in the 'gauge budget' either, so I went with a factory repro tach dash setup.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
