Old 03-22-2009, 08:29 PM   #1
terd ferguson
terd ferguson's Avatar
Anybody Cut the Front Bumpstop Brackets to Get a Little Lower?
I'm down in the front as far as I can go with cut coils, drop spindles, short shocks and everything else stock. I notice the front bumpstops sit on 2" or so high "bumps" on the lower A-arm. Has anybody cut out this "bump" that the bumpstop sits on to get a little more lower/supsension travel? It would seem I could gain another two inches of lowering/travel by cutting these "bumps" out and remounting some shorter (non factory) bumpstops.
If you've done this, some pics and descriptions would be most helpful.
So what say you? As always, thanks for any and all help and/or suggestions. And thanks for this great forum.
"I never apologize. I'm sorry, but that's just the way I am." - Homer J. Simpson
1955 2nd Series Chevy "King Of Trucks"
terd ferguson is offline   Reply With Quote
Old 03-22-2009, 08:33 PM   #2
Reyals Bemus
Re: Anybody Cut the Front Bumpstop Brackets to Get a Little Lower?
Like I mentioned on the HAMB, my friend is thinking about doing that. We're trying to think of why they're there from the factory...? Maybe its cause with stock wheels/tires, they might hit the inner fender at full compression? Dunno, but it seems like cutting those brackets out would be helpful...
Reyals Bemus is offline   Reply With Quote
Old 03-22-2009, 08:40 PM   #3
terd ferguson
With the drop spindles, short shocks, and cut coils, the tire would rub on the battery box when turning left to full lock. I had to cut out part of the battery box. If I go lower, I'll more thanlikely have to relocate the battery and cut the box out entirely. With that said, I'd still like another couple of inches lower in the front. I figured I'd ask here about cutting the bumpstop brackets as there would be a higher probability of someone having done it (vs. the hamb).
I don't think fender clearance would be an issue with just a couple more inches. At least in my case, it looks like I'd be fine fender clearance wise.
I found some bolt in bumpstops that are stepped so you can trim them to the desired length at the local Andvance Auto for pretty cheap. It seems like I could just cut that "bump", drill a hole, and bolt in the new bumpstops and gain two inches. But, I'd like to see if anybody else has done it first. :tito:
Old 03-22-2009, 08:42 PM   #4
protrash64
Resistance is Futile
protrash64's Avatar
I cut them out on both my trucks....do it.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-22-2009, 08:44 PM   #5
terd ferguson
Details? Got any pics? Did you reuse the factory bumpstops or something else? Any issues with tire/fender clearance, etc.? Thanks.
Old 03-22-2009, 08:51 PM   #6
protrash64
protrash64's Avatar
Well.....no pics. Just pop the a-arms down and drill the whole assembly off the LCA. I used a spotweld cutter. I did it for the same reason you mentioned and then I bought the appropriate sized tire so as not to have interference problems. I dont have any bumpstop in either of my trucks. The pick-up has 2.5'' spindles and 3'' coils and 26.5 '' diameter tires. I dont rub and have bottomed out only once when I hit a speedbump a little fast. Airbag guys remove it all the time.
Old 03-22-2009, 08:54 PM   #7
terd ferguson
Thanks a lot for the info. I'm going to give it a shot in the next couple of days.
Old 03-22-2009, 08:58 PM   #8
protrash64
protrash64's Avatar
If you're bottoming out it will free up the space. Just too bad you didnt do it when you had it apart before....but still worth the effort now. You could add a bumpstop on the edge of the coil pocket, I suppose???
Old 03-22-2009, 09:40 PM   #9
terd ferguson
I don't think I'll have to take it back apart to get at it. I think I can just remove the tire, jack up the front end to let the control arms droop and cut the bump from there.
The bumpstops I saw at the parts place had an integral bolt and would only need a small hole drilled in the LCA and thightening the nut.
Old 03-23-2009, 12:07 AM   #10
protrash64
protrash64's Avatar
I didnt think of that...probably work and if you have a righthand drill you should be able to get it done. Mite be able to grind them down, too.
Old 07-12-2009, 01:02 PM   #11
daverod
SSN 706
daverod's Avatar
Can you leave the a arms in place and cut the coils? I'll answer myself. No, take the time to clean the 50 years of crap off the u bolt nuts. Put a jack under the arms, jack it up alittle , undo the the u bolt nuts, remove and cut springs. Cut the springs with a grinder and cutting wheel. Replace in reverse order. Easy. Worse part was the cleaning.
daverod is offline   Reply With Quote
Old 07-12-2009, 08:07 PM   #12
1stseries55
1stseries55's Avatar
good timing on this one... I am almost finished with my front end conversion. All the parts are from an 87 burb. It has 2.5" drop spindles and 3" coils. I know I will have to trim the bumpstops but do you think I will have issues with the bumpstop mount itself? I am running a 15" wheel. Here is a pic..
nothing hits now but obviously there is a lot of weight that is yet to be put back on the front. What do you guys think?
Jared
USMC 1st Battalion 8th Marines (95-99)
55 1st Series 3100 (on 98 sonoma frame)
65 GMC short bed fleetside big back window
http://67-72chevytrucks.com/vboard/s...d.php?t=358493
1stseries55 is offline   Reply With Quote
Old 07-12-2009, 08:53 PM   #13
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Yeap...those are the first things to go if you want any 'travel' at all.
My truck uses stock spindles, cut springs and short shocks and it rides good.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 07-12-2009, 10:50 PM   #14
terd ferguson
Attachment 478028
You'll probably want to shave those brackets. With drop spindles and two ut coils, mine rides on the brackets. I've had some shaved control arms for a while. I'm finally getting around to installing them this week. My kidneys can't wait.
Old 07-13-2009, 12:13 AM   #15
joe231
joe231's Avatar
yeah you are gonna want to remove those...from the pic you only seem to have a couple of inches of clearance, and like you said you have a lot more weight to go on the front
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 07-13-2009, 12:47 AM   #16
Frizzle Fry
Frizzle Fry's Avatar
I cut mine but left the steering stop portion in place. It may not look like it from this angle but it clears the upper plate to full bag compression:
Frizzle Fry is offline   Reply With Quote
Old 07-13-2009, 12:59 AM   #17
protrash64
protrash64's Avatar
I took mine totally off so its more aerodynamic and I can manuver drive thru's better, let alone the fuel savings
Old 07-13-2009, 01:07 AM   #18
Frizzle Fry
Mine also serve as vertical stabilizers and bottle openers when aired out
Old 07-13-2009, 06:28 AM   #19
63 & 64 Bowties
and a few others
I cut mine after I got it all together. Not by choice, just dumb. I used a sawzall. Not pretty, but it works.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 07-13-2009, 06:44 AM   #20
1stseries55
thanks... fortunatley at this stage it will be easy to drop the lca's and remove them.... thanks fellas
Jared
Old 07-17-2009, 12:28 PM   #21
sams60gmc
sams60gmc's Avatar
Hey Chief how much did you cut off your springs, I really like the ride height of you truck.
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline   Reply With Quote
