Old 07-29-2009, 11:22 PM   #1
ozman3803
Angry clutch linkage coming up short...help!
Ok, 70 chevy 2whl with no eng. but was orig. inline 6 and 4spd manual. Dropping in 350 but main concern is the clutch linkage. Finally found what I needed out of a 70 chev 3/4Ton 2 whl with v8. Pulled everything from clutch pedal to shift fork. Put it in my truck and it's coming up about 3 inches short from clutch fork. What is the problem? Looks like I could move the bell housing but not sure if I want to do that, then I'llll be looking for a driveshaft. Any Ideas? Also same bellhousing should work with v8 right?
ozman3803 is offline   Reply With Quote
Old 07-30-2009, 12:02 AM   #2
mclairmo
Re: clutch linkage coming up short...help!
Can you buy some threaded rod and make up the difference? If not, break out the welder or find another donor truck and strip out what you need.
mclairmo is offline   Reply With Quote
Old 07-30-2009, 06:44 AM   #3
'68OrangeSunshine
'68OrangeSunshine's Avatar
The L6 uses a different Z-bar than the V8s.
Old 07-30-2009, 04:10 PM   #4
Wrenchbender Ret
Are you sure the T.O. brg. matches the clutch?
Wrenchbender Ret is offline   Reply With Quote
Old 07-31-2009, 12:31 AM   #5
Jim_PA
Did you put the 8 in the same motor mount position as the 6?
Jim_PA is offline   Reply With Quote
Old 08-01-2009, 06:57 PM   #6
ozman3803
Thanks for the input everyone. It's a v8 clutch linkage setup that i put in. The tranny shouldn't be in a different position if it was a L6 would it?
Old 08-01-2009, 07:33 PM   #7
71tahoe
71tahoe's Avatar
Unless you moved the crossmember for the bellhousing all the I6 hardware will work. At least for a 250 it will.
71tahoe is offline   Reply With Quote
Old 08-01-2009, 07:50 PM   #8
ozman3803
the crossmember had rivet type bolts in it so it don't look like it was ever moved. It looks like it has predrilled holes that could look like it could be moved up. Don't really want to move which of course would change drive shaft length.
Old 08-02-2009, 01:02 AM   #9
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
All I know is when I went from my L6 to my BBC, I had to cut and slide the frame mount for the Z bar down. I also had to really lengthen my rod to the clutch fork too. It's because those granny 4 speeds are so short. Wait a minute.....are changing trannys too or just the motor?? I might not have read the thread correctly.
prostreetC-10 is offline   Reply With Quote
Old 08-02-2009, 04:14 PM   #10
ozman3803
motor only will be changed with small block. What could I use to lengthen pushrod. I know ready rod is going to be to weak. Any ideas or has anybody else ran into this?
Old 08-02-2009, 04:31 PM   #11
71tahoe
71tahoe's Avatar
If the tranny doesn't move and the z-bar bracket on the frame doesn't move and the cab doesn't move, just use the i6 z-bar and screw in the pivot ball to the v8 block. There should be a tapped hole directly across from the frame bracket. If you're running headers you may need to put an offset in the lower part of the z-bar.
Old 08-09-2009, 05:34 PM   #12
'68OrangeSunshine
When I went with a Centerforce II clutch on the SM465 behind a V8 350 in my '71 GMC Jimmy [K/5], for some reason -- I think it was easier than pulling the whole engine,transfer case and transmission again just to put in a different throw-out bearing -- I had a welder attach a threaded section of a '73-later GM clutch pushrod onto my old '71 pushrod. He used a 3" section of 9mm submachinegun barrel, he claimed, for a splice over the butt weld of the 2 rods.
I also joggled the "ears" of the Z-bar to clear the headers.
Still working 10 years later.
