new wheels...pic's
ok 20x10 all the way around
basic mods front 1/4 spacer and longer studs rear 1.25 inch spacer (for look only) machined the center of the front wheel larger(don't really know if that helped) machied the rotor where the dust cap is (machied down to the race) turning problems......none dust cap used......no if i would have had the rotor machined down and machined thiner, as i seen someone else do no spacer would have been needed center cap moded..no spindel type western chassie 2.5 mod the spindal.....no looked bad ass.....................................................YES ![]() ![]() ![]() ![]() ![]() |
Re: new wheels...pic's
very bad @ss! nice job man!!!
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
Low & Fast!
Very cool looking! What size tires are you running?
Just so you know--I once had to machine a rotor/hub down to fit a wheel for a Buick. A lot of material had to be removed. It was a pain. I dreaded ever changing the rotors, because I knew I would have to do it again. Well, the day finally came to change it. I went to the parts store and bought a set of rotors. Stock replacement, just like the other ones.
Come to find out, that brand fit in there just fine. I did all that for nothing the first time--because I didn't check around. Looks really good though.
Joseph 87 Turbo Buick 92 5.0 Mustang coupe 87 GMC Sierra SWB 82 Chevy K5 Blazer 2wd |
i work at a auto shop, i tryed 3 just to be sure, machine shop only charged $20
2453520 2753520 plan to go to 2753520 3053520 |
Cool. When I did mine, I couldn't find a machine shop that would even touch them. But I had a close friend that managed the neighborhood Napa. We actually did it on a brake lathe. We flipped the bit over on a drum lathe and went to town. It took about 3 hrs per rotor.
![]() It's gonna look real good with that fat of a tire on the back. I don't remember if you've said, but do you plan to change the color?
Joseph 87 Turbo Buick 92 5.0 Mustang coupe 87 GMC Sierra SWB 82 Chevy K5 Blazer 2wd Last edited by jdurant; 07-28-2009 at 03:50 PM. |
white with candy blue flames outlined in lime green
Nice blazer and wheels
Looks really good
70 SWB STEPSIDE 70 BLAZER 09 challenger |
![]() Join Date: Jul 2009
Looks good!
When you say your not using a "dust cap" are you talking about the grease cap on the rotor? |
Tot Roddin'
Those look good, nice choice!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
^^^ What's gonna keep the grease in the rotor when it gets heated up during driving? Won't the grease be "slung" out and the bearing fail?
