Old 08-20-2009, 09:05 AM   #1
brian mac
pinion angle help needed
I am changing my 68 GMC from leaf rear to coil rear. It has stock trailing arms and 4 inch lowering coils. I need to know where to set the pinion angle before I weld the axle saddles to the axle tube. This is being done with the truck totally disassembled (body off frame no engine or tranny).
brian mac is offline   Reply With Quote
Old 08-20-2009, 04:57 PM   #2
jjjmm56
jjjmm56's Avatar
Re: pinion angle help needed
It might be hard to determine without the motor and trans in. You need to know what angle your tranny output shaft is at.
jjjmm56 is offline   Reply With Quote
Old 08-20-2009, 05:26 PM   #3
fixit-p
fixit-p's Avatar
Yeap your pinion angles are dependant on one another (trans yoke and rear end yoke) here is a good resource for drivelines and installation http://www2.dana.com/pdf/J3311-1-HVTSS.PDF
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
