Old 09-04-2009, 04:27 AM   #1
OARNGESI
OARNGESI's Avatar
NArrower rearend
hi does anyone know of a rearend thats 5x5 pattern but a couple inches narrower on each side than a stock 72 one like 2-3 inches total. maybe a 88-98 or even like a 95 caprice anyone ever done a swap like this rather then cut one down thanks for replys
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 09-04-2009, 09:39 AM   #2
ShowSS12
ShowSS12's Avatar
Re: NArrower rearend
I remember look at the flange numbers for a 72 Axle and a 96 Impala axle and the Impala being 2-3" bigger. But I think a earlier 67-69? Is a bit shorter but only a few inches. But don't quote me on that I could be wrong.....
Adam M
STX Designs
Motorcycles | Choppers | Hotrods
ShowSS12 is offline   Reply With Quote
Old 09-04-2009, 09:53 AM   #3
OARNGESI
OARNGESI's Avatar
So the impalas are wider i know the 69 rearend on a c10 is 1.5 inches narrower total i need that per side so 3 total
70 SWB STEPSIDE
70 BLAZER
09 challenger
Old 09-04-2009, 01:18 PM   #4
Primer70
Superbad
Primer70's Avatar
We narrow the rear end housings at my work & use Dutchman
Motorsports steetable custom alloy race axles. Total cost should be around $500 - $600, depending on what it cost you the have the housing narrowed.
Primer70 is offline   Reply With Quote
Old 09-04-2009, 06:02 PM   #5
GVizzle
GVizzle's Avatar
You can find the 65 - 69 12 bolt rears at a junk yard.
I picked one up for about 150 then bought dutchman 5x5 axels for 300 from ECE.
The flange to flange width is 56.5. They are 1.5 inches narrower that the 70.5-72 12bolts.
Becareful not to buy the wrong one! I had to buy two.
GVizzle is offline   Reply With Quote
Old 09-04-2009, 06:23 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
I believe the 2nd gen camaro axles are close to those dimensions. Since your going to have to buy axles, you could have set built or redrill those for 5x5.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
