Old 06-04-2009, 12:36 AM   #1
cheyenne10
cheyenne10's Avatar
Tach/vac & tach dashes fs
I am selling 2 tach dashes in this post. (both V8 tachs) See other post for tilt steering columns.
1st dash setup is a factory chevy tach dash including hard to find vacuum gauge. I used a setup like this in my restored suburban for truck loaded with factory options. I dusted this one off and added a new bezel that was drilled for Speed warning knob and my rear AC, (was planning 2nd 2 wheel drive 1968 burb). The stock bezel I pulled off was from a 68-69 truck that had the headlight switch, wiper switch and a choke knob labeled accordingly. This bezel is avail. if desired by purchaser. Still could use a lense polishing but printed circuit board looks great and all needles look fine too. No rust in internals of gauge faces as sometimes found. $325+ shipping
2nd dash is a regular tach dash. Circuit board looks even better than 1st, dusty inside gauges, no rust visible, should clean up fine to use as-is or restore, again no visible rust inside. (did not pull this bezel). $225 + shipping.
Bob
cheyenne10 is offline   Reply With Quote
