Old 09-23-2009, 03:56 PM   #1
Smokin72on20s
Ebay Junky
Smokin72on20s's Avatar
Opinion: Typhoon engine in a 72..
Im looking to put a 93 GMC typhoon engine into my 72 short bed 2wd. I was going to use a stock 700r4 so no awd. I really like this motor and it would def. be a unique swap. Also, since its essentially a small block, the swap shouldnt be too hard and the power is good enough to make this truck pretty quick. Your thoughts/opinions? And yes, i know this is not practical, but say i wanted to do it.
1972 CHEVY C-10 SWB 2WD - Possible Typhoon 4.3 turbo drivetrain..
1983 Chevy c10 swb 2wd - possible 350tbi supercharged...
Smokin72on20s is offline   Reply With Quote
Old 09-23-2009, 04:05 PM   #2
SactoJim
SactoJim's Avatar
Re: Opinion: Typhoon engine in a 72..
Sounds like a cool idea to me......I go with a build 200R4 for the better 1st - 2nd ratio spread. Probably help a little with keeping the turbo spooled up.
I've always loved the Cyclone and Typhoon.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 09-23-2009, 04:26 PM   #3
Smokin72on20s
Ebay Junky
Found a typhoon motor, has a main bearing knock however, shouldnt be too hard to rebuild, guy hasnt given me a price yet, its just like rebuilding a regular 4.3 v6 right?
Old 09-23-2009, 04:41 PM   #4
truckster
truckster's Avatar
If my memory serves, the Typhoon and Syclone only had about a 400 lb. load rating. I'd check the curb weight against the weight of your truck and how you intend to use it.
truckster is offline   Reply With Quote
Old 09-23-2009, 05:09 PM   #5
Smokin72on20s
Ebay Junky
Just going to use it as a cruiser, not going to pull anything. I think a shortbed 2wd 72 pickup weighs about the same as an awd typhoon.
Old 09-23-2009, 05:12 PM   #6
6772owner
Gearhead
6772owner's Avatar
I would say that the load rating had to do with the full time t-case, but I could be wrong. Sounds like a cool idea to me, and I havent seen one yet, so unique as well. Go for it!
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 09-23-2009, 05:31 PM   #7
QKENUF4U
QKENUF4U's Avatar
sounds cool.... if ya can afford it then go for it.... def. different....
QKENUF4U is offline   Reply With Quote
Old 09-23-2009, 05:39 PM   #8
mclairmo
Sounds cool to me.
mclairmo is offline   Reply With Quote
Old 09-23-2009, 05:41 PM   #9
texanidiot25
Eat My Rust
texanidiot25's Avatar
When you consider that this turbo version puts out way more than the normal 4.3L V6 that they put in the bloated GMT800s and early 900s, this motor will be fine.
The 4.3L V6 thinks it's a V8 when it comes to torque, it will be fine.
texanidiot25 is offline   Reply With Quote
Old 09-23-2009, 05:47 PM   #10
Thealien
Thealien's Avatar
I like the idea. Always liked the typhoon
Thealien is online now   Reply With Quote
Old 09-23-2009, 05:53 PM   #11
neonlarry
neonlarry's Avatar
Just make sure you get the wiring harness and computer.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 09-23-2009, 06:12 PM   #12
Smokin72on20s
Ebay Junky
so 200R4 trans vs. a 700R4 with this set-up? What kind of gears should best? looking for quickness, not top speed, also, i will be running a 20" wheel
Old 09-23-2009, 06:39 PM   #13
SactoJim
SactoJim's Avatar
3.73:1 seem to be the best choice when using an overdrive auto. Have a 700 in mine with 3.73......no complaints.
- supercharged 383
- 4 wheel discs
My Build Thread
Old 09-23-2009, 06:41 PM   #14
big_al_71
big_al_71's Avatar
That built will be totally I have considered puttin a single turbo 2jze from a supra into an old bucket trying to copy the old farm truck and do some serious quiet spanking to others on the road....go for it keep us posted...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 09-23-2009, 08:53 PM   #15
sourkraut
sourkraut's Avatar
That would be super cool! Have you seen that one guy on youtube that has his cyclone all hopped up and rippen down the street? I say go for it!
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
