Old 10-02-2009, 12:10 AM   #1
fred1968
1968 3/4 ton rear axle hub size
I have a 1968 2wd 292, 4 spd 3/4 ton truck with coil spring suspension. I am looking for information on where to get a set of 4 16" stamped steel wheels for my truck and I would like to know if there is a particular year(s) that will fit over the larger rear wheel hub. The rear end in my truck is NOT the Dana.
fred1968 is offline   Reply With Quote
Old 10-02-2009, 04:23 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 1968 3/4 ton rear axle hub size
Fred, welcome to the board! That is a beautiful 68 custom/20... don't see too many around that nice... esp up north.
The rear end in your truck is the Corperate rear. It is sometimes called the eaton. What it is, the eaton differental in a corperate axle, and is also called the HO52.
Wheels off of any 3/4 ton or single rear wheel one ton will fit up till 2000 or so. I think fords chainged a little sooner than 2000 though. There's a few things to consider on this however.
If you plan on hauling a lot of weight on a regular basis, then you'll want to stick with GM wheels. The center hole on the Ford and Dodge wheels are larger (and most aftermarket wheels too) and that is actually where the weight of the truck rides. Once you install a wheel with a larger opening for the hub, then the weight of the vehicle and load alll gets placed on the lug nuts. If you just use the truck as a daily driver and not for hauling/towing all the time, then you'll have no problems with an 'other brand' wheel.
Also, in 71, GM went to a larger wheel stud and lug nuts. 9/16ths up from a 1/2 inch stud. THis is actually not an issue. The taper of the lug nut centers the stud in the hole of the wheel, and it still holsds the wheel fine. I have personally been running my C/30 longhorn with later wheels since 2005, and one I had before that for 2 years also, absolutly no problems. If it bothers you, you can update the front end to disc brakes, and then swap in a newer rear end. (once you do a full brake job on this old drum/drum set up, you'll want to update for other $$$ reasons) Some have been able to redrill the hubs and install the larger wheel studs too.
On the stock steel wheels, you'll want to watch the back spacing too. It bothers some more than others, but the newer the wheel, the more back spacing it got from the factory, and the wheel gets placed further into the fender. On stock wheels it isn't a problem of rubbing, but it just looks funny to some.
The 16 inch non split rims on GM trucks started sometime in the late 80's to early 80's. They may have been optional sooner, but i am unsure. I do know my 78 parts suburban came with 16.5 wheels. You can allso find the wheels on vans too.
Don't be in too much a hurry, these wheels can be found dirt cheap, even free. I have personally given 6 or so 16 inch 8 lug wheels away, and have had at least 10 or 12 given to me over the years.
Junk yards and used tire stores are both good places to locate them.
Old 10-02-2009, 04:46 PM   #3
fred1968
Thanks dude
Old 10-02-2009, 08:28 PM   #4
ERASER5
ERASER5's Avatar
LHM has got you covered, so all that is left for me is to say Welcome!
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 10-02-2009, 08:48 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
Welcome to the Board. I was able to pick up some 16" x 8" 8 lug steelies on Craig's List. Don't know what they came off of though.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 10-02-2009, 10:05 PM   #6
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
Welcome. Gota love the light green 3/4T.
I've got two 16 x 6 that could be had cheap. Not sure what the shipping would do to you, though.
I'd post pics if the card reader would cooperate.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 10-03-2009, 02:56 AM   #7
Longhorn Man
don't turn this into a parts thread... I'd hate to see a member's first post get locked up
