![]() Join Date: Jan 2009
Just ran across an '87 Chevrolet Blazer 4X4, cheep. I have no desire for a 4X4, does anyone know if a two wheel drive front crossmember will directly bolt in as in a '67-'72?
Dasani a.k.a. Tom |
Low & Fast!
Re: Blazer 4 to 2 wheel drive?
I know you have to add some holes to the frame, but not sure were. Someone will pop in and tell us..
Happy to be here
![]() Join Date: Mar 2000
It will work, but will require some drilling. Up until 82 when they made the last 2wd Blazer the holes were there. At some point, maybe 83 they stopped punching the extra set of holes required.
You might have to get some measurements off of a 2wd donor frame to be sure that it lines up.
just take the front drive shaft out
"I'll keep my guns, money, and freedom. You can keep the "change" |
huh ???
This thread should answer most all of your questions.
http://67-72chevytrucks.com/vboard/s...d.php?t=168231 Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
There is also some good info in my build thread. The link is in my sig.
I havent started the suspension swap though, I only have the 2wd torn down. I hit a brick wall in getting the rivits out of the shackle hangers.....
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
can i have the dana 60?
