Old 10-24-2009, 01:26 PM   #1
Gemp
Gemp's Avatar
Picked up a 76 2wd Jimmy
I just pick up a 76 2wd....Found this thing across town. You never see 2wds around here this nice,this cheap. Body wise it needs some work,over all not bad. Its has been sitting in a garage for 10 years. 327,M22 4-speed....It should be fun. It runs and moves with 10yr gas. Very rough...but it runs.
Here is some pics he sent me to hold you guys over until I get better ones.
06' GMC 1500 Crew cab.....
Gemp is offline   Reply With Quote
Old 10-24-2009, 02:26 PM   #2
CoyoteCustoms
CoyoteCustoms's Avatar
Re: Picked up a 76 2wd Jimmy
What did you give for it if you dont mind me asking? I am looking at one in about the same condition.
CoyoteCustoms is offline   Reply With Quote
Old 10-24-2009, 02:31 PM   #3
Gemp
Gemp's Avatar
$1500
Old 10-24-2009, 02:37 PM   #4
cochino12
It followed me home?
cochino12's Avatar
Originally Posted by Gemp View Post
$1500
not bad!! I like
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 10-24-2009, 05:22 PM   #5
SBTork
Garage wrench
SBTork's Avatar
Nice score, it's well worth the money spent. I never see 2wd K-5's of any year around here, let alone that decently priced. On a side note, that engine does not look like it's been sitting untouched for 10years. And it looks like it's already lowered a good bit too.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 10-24-2009, 10:15 PM   #6
Gemp
Gemp's Avatar
He rebuilt motor it in 99 and put a few miles on it, started the bodywork and let it sit.
This is my 3rd K5,but my 1st pre 82'. I just realized the bed floor runs up the front seats. This truck don't have a rear seat in it. It has aftermarket carpet,so I haven't looked under to see if there are holes for a rear seat.
Was the rear seat an option? Do all the round eye truck have no foot well area in the back, or did some have it?
Edit***Google says.......In 78' the floor changed
Old 10-24-2009, 10:23 PM   #7
tvblazer78
Low & Fast!
tvblazer78's Avatar
Not bad at all!
tvblazer78 is offline   Reply With Quote
Old 10-25-2009, 11:31 PM   #8
Gemp
Gemp's Avatar
Has anybody mounted a 78'+ rear seat in a 77' and later flat floor truck?
Old 10-26-2009, 09:12 AM   #9
tvblazer78
Low & Fast!
tvblazer78's Avatar
Any of the blazer seats should work. I know the 73-85 will and I think it will work up to 91. But not for sure on that one.
Old 10-31-2009, 09:25 PM   #10
USSkoval
I'm in the process of doing just that. However, I'm doing it slightly different than original. I'm raising the seat a little off the floor, closer to the hight of the original '77 seat. This is to provide room for the seat to fold forward, since a flat floor is there. It also gives a little leg room. I can take some pics if you would like to see what I'm doing.
USSkoval is offline   Reply With Quote
Old 11-01-2009, 11:15 AM   #11
Gemp
Gemp's Avatar
Yeah,I like to see your set-up. I want to do the samething,it would be nice to have it still fold forward.
Old 11-01-2009, 02:11 PM   #12
USSkoval
Here is the seat bolted at the front and sitting level.
Here is the seat folded forward, plenty of clearance at the floor.
This is a front shot of one of the spacer blocks I made.
This is a shot from the rear, with the seat folded forward. It's grade 8 hardware, with a large washer under the floor. I use large washers with a rolled edge for everything that bolts to the floor.
Old 11-01-2009, 02:34 PM   #13
USSkoval
For the rear, I will use u-bolts for the seat to latch into. The one pictured is for an Astro van, but I'm going to have some thicker, square-ended u-bolts custom bent to use instead. I'm going to weld washers to them to set the correct hight, then bot them down tight from underneath.
Here's a shot of my Suburban that I added in the rear seat, please excuse the dirty carpet. This is how it would be done in the Blazer if I were keeping the seat low to the floor. The Blazer and Suburban use the same floor hooks.
In this pic, you can see how I added in the floor hooks and bolted down the seatbelts. I cut the floor hooks out of a donor truck, cut holes in my floor big enough to accommodate the pocket, then riveted them in with ten 1/4 rivets on each floor hook. The next time I have the gas tank out, I will probably weld them to the floor pan, and also weld the seatbelt nuts and washers to the floor.
Old 11-01-2009, 04:24 PM   #14
Gemp
Gemp's Avatar
Great pics, I think the folding seat is going to be the way to go.
