Old 10-23-2009, 12:45 AM   #1
joe1982
.. !WAR FEDOR! ..
joe1982's Avatar
stock rally wheel question.........
dumb question here.. what hardware is required to mount stock rally wheels, AND, the center caps. i know there are 3 bolts that mount the cap to the wheel, but what nuts are used on the actual studs?? does a set of nuts bolt the wheel on, then the cap goes on then other nuts?? just a bit confused. oh, and where would i be able to purchase this nut set? thanks guys.
-joe
"san diego chargers #1"
joe1982 is offline   Reply With Quote
Old 10-23-2009, 01:21 AM   #2
spyderman1977
Re: stock rally wheel question.........
As for the lug nut you can go down to AutoZone and pick up a set of standard lug nets in a set of 20 with locks for around 25 dollars at least here locally. I am not sure if you can get them without the locks that would be by store I would guess. You can also buy them individually from behind the counter if they have 20 for about the same price as the set with the locks. I think I got some for right at 99 cents but took a while for the store to get in all 20 for the 4 wheels.
The center caps you can get the bolts at a local hardware store. I can't recall the size but I am thinking its 5/16 but that sounds a bit large to me.
Depending on where you get the bolts for the center cap ( LMC should have OEM bolts ) as long as the bolt doesn't extend past the wheel you should be able to put the cap on with the wheel on or off the truck.
Paul
2 Chevy Monzas and 5 Buick Skyhawks
1 53 Chevy Truck....1 69 Chevy C/10.....1 72 Chevy C/10....1 69 Chevy C/20
1 83 Chevy El Camino SS
1 98 Chevy Tahoe 2dr 4x4 ....1 02 Jeep Liberty Limited
In loving memory...Dad: David Nelson (5/24/38-2/14/2007) and Mom: Betty Nelson (3/6/51-1/5/2010)
spyderman1977 is offline   Reply With Quote
Old 10-23-2009, 06:28 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Three 5/16" bolts hold the stock center cap to wheel.
73-87 trucks:
2wd 1/2 ton trucks require a 1/2" lug nut.
4x4 1/2 ton trucks require a 7/16" lug nut.
Keith
Convert to disc brakes.
Old 10-23-2009, 07:25 AM   #4
Keith Seymore
Keith Seymore's Avatar
73-87 trucks:
Yes - and just to add, they are a steel nut with a stainless acorn style cap. I got mine at a local swap meet.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-23-2009, 07:27 AM   #5
fiddy9apache
fiddy9apache's Avatar
spider man thats a nice rally, i like the two tone.
i run rallys on everything. if im not running big billet wheels im running rallys lol
fiddy9apache is offline   Reply With Quote
Old 10-23-2009, 09:45 PM   #6
spyderman1977
Thanks...It was going on an Orange truck. I completely sand blasted the wheel back to bare metal.
I went on a whim to try the simulated chrome on the wheel. The owner of the truck didn't have the beauty rings at the time I was working on the truck. It turned out looking pretty nice without the rings on. Even with the rings it still added a nice touch. Also when I painted the bowtie the same orange it made it really stick out on the truck as well versus the yellow.
I also did a black wheel as well but the orange looked better with the orange truck.
I posted the pic to show that you should be able to get the cap on with the wheel off as the orange showed through the cap.
As a side not when I get around to my 72 I will probably go the same route I went with these wheels only a different color or course
Paul
Last edited by spyderman1977; 10-23-2009 at 10:49 PM. Reason: Knew I had another pic somewhere
Old 10-23-2009, 10:32 PM   #7
fiddy9apache
thats chrome in a can?! that turned out nice
Old 10-23-2009, 11:05 PM   #8
spyderman1977
Yes but it was a PITA trust me to get it to come out smooth. The black wheel happens to be flat black btw. Its got me thinking instead of blue for my 72 I may go with flat black now since I have a set of ralleys on it now...
Before and after pics from the same truck.
Paul
