Old 09-20-2009, 12:16 AM   #1
basemodel67
Factory Strippers Rule!
basemodel67's Avatar
Too much work?
Hey, my neighbor has a full convertible Blazer 4wd with a 90 suburban front clip. It has about zero rust and the top is in great shape. The problem is that I prefer the 73ish style front end and don't want a 4 wheeler. How much work would I be in for to make it 2wd and switch the front clip? Is it worth getting for $500? I don't think it runs, but that doesn't really matter. Input, please!
"Feast your eyes on a feast of smoke."
67 Chevy Short Fleet
PLAN: LQ9, 4L60, D60
Looking for School Bus Gauges - Help me out!
basemodel67 is offline   Reply With Quote
Old 09-20-2009, 12:41 AM   #2
2tons of fun
Re: Too much work?
seeing as how the cab was designed for a 73-80 front clip it will be a easy swap back.
the 2wd stuff will be different, you will have to drill a lot of holes in ****ty spots and cut a lot of rivots, it the end it will all fit but its a chore.
2tons of fun is offline   Reply With Quote
Old 09-20-2009, 08:42 PM   #3
bluex
bluex's Avatar
Re: Too much work?
He wont have to drill holes. They should already be there on a 73. They stopped putting them in the frames after 82 when 2wd was no longer an option on a K5. You will have to cut the rivits holding the 4wd stuff on, and the whats holding the 2wd stuff on the other truck. It should be a bolt on after that though.
This is what I have been able to find as I've been researching my swap. I have an 87 I'm converting to 2wd.
See this thread for reference: http://67-72chevytrucks.com/vboard/s...d.php?t=168231
This is an 82+ truck as well so he had to drill the holes too. My build thread is in my sig, but I havent started the suspension swap yet.
bluex is offline   Reply With Quote
Old 09-21-2009, 08:44 AM   #4
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Too much work?
That's a good price for that blazer. And to turn it back into a 73-79 front end is easy, just takes time. Now on your front end to make it a 2wd yo uwill have to buy you ca 2wd truck and take the crossmember out and put it into the blazer and will will also have to chang the hangers out back, the 4wd and 2wd are not the same.
Good luck.
tvblazer78 is offline   Reply With Quote
Old 09-23-2009, 04:17 PM   #5
Damien
Damien's Avatar
Re: Too much work?
$500 for a rust free tub in MN is unheard of!
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 09-30-2009, 09:21 PM   #6
Conundrum
Conundrum's Avatar
Re: Too much work?
I say buy it if you haven't already
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r
http://67-72chevytrucks.com/vboard/s...d.php?t=460030
97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver
220,000 miles, all stock for now
Conundrum is offline   Reply With Quote
Old 10-21-2009, 02:50 PM   #7
justpball
justpball's Avatar
Re: Too much work?
^+1
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
