Old 10-23-2009, 05:43 PM   #1
BADPURPLE70CHEVY
406 Powered
BADPURPLE70CHEVY's Avatar
locker in your diff?
Anyone put a locker in there rear end? I have done alot but i have not done this. How bad is it?
70 GMC
68 c10
2002 silverado
72 4x4
BADPURPLE70CHEVY is offline   Reply With Quote
Old 10-23-2009, 05:53 PM   #2
Fenny
Junior Member
Re: locker in your diff?
Mine had a detroit locker in it when I had a dana 60 in the rear. I had no problems with it.
72 GMC 3/4 ton Custom Camper 5.3 ltr 4l60e
72 Chevy Blazer 4x4 327 4spd
70 Olds Cutlass supreme 455 4spd m21
Fenny is offline   Reply With Quote
Old 10-23-2009, 05:57 PM   #3
Fitz
No different than installing an Eaton Posi. Took 10 min. to get the unit in and 2 hours to get it correctly shimmed for pattern and backlash. Don't try it unless you have a dial indicator to measure the backlash and when you put it together tighten the nut on the pinion just finger tight or you'll be making a trip to the parts store for a new crush sleeve each time you have to change a shim. If the backlash isn't right you'll be breaking gear teeth. When correct the backlash should be somewhere between 0.003 and 0.007 inches and the pinion gear teeth should leave neat little half moons in the CENTER of the ring gear teeth as shown in the photo. Then you can tighten the nut on the crush sleeve on the pinion. Get the pattern marks too near the outside of the ring gear and same result as poor backlash...broken teeth the first time you back off the throttle then get back on it!
Fitz is offline   Reply With Quote
Old 10-23-2009, 07:39 PM   #4
LONGHAIR
If all you are doing is changing the carrier to install a Detroit Locker, you don't even need to touch the pinion....but you do need to get the backlash correctly re-set. It should be set to Exactly where it was....pretty much reguardless of what that actual number measures to be. So to that end, you must check it before you take it apart. Swap the ring to the new carrier and adjust the shims to get the same measurement as before. Do not bother the pinion, as far as that goes, you don't even need to disconnect the drive shaft.
The "contact pattern" is irrelevant at this point. It will have worn into whatever it has now and you must not change that....damage will occur if it does.
I said "pretty much", before in the pre-removal measurement stage of backlash...because there is alimit here. If your pre-removal backlash measurement is too big, I wouldn't spend the time or money on these gears. You cannot "just tighten it up"....That will destroy it even faster.
Did I mention the backlash has to be exactly where it was before?
One more thing......Synthetic gear lube
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 10-23-2009, 09:35 PM   #5
hayhauler71
hayhauler71's Avatar
I have been using a lock rite locker in my 71 for 3 years now with no problems or noise. One hour to install.
hayhauler71 is offline   Reply With Quote
Old 10-23-2009, 10:49 PM   #6
BCOWANWHEELS
Hope you have alot of money to replace back tires, a locker is hard on em also on wet roads it will spin you out quick if you break em loose oh did i mention your fuel milage will go "down "
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 10-24-2009, 12:43 AM   #7
Pont406
I just got this one in tonight. I'll try it out tomorrow.
Pont406 is offline   Reply With Quote
Old 10-24-2009, 12:52 AM   #8
69TowRig
I have a Lock-Right in my K5 and a Detroit in my Nissan. Both work great. The Lock-Right, had my carrier not had issues, would have been a breeze to install. The Detroit required a carrier replacement and that took some time to do properly.
I cannot imagine how fuel mileage would suffer noticeably with a locker installed. Under power the carrier will drive the inside tire in a curve and let the outside tire over-run the carrier. There is no loss of energy here. If I drive like "a normal human being", which isn't often, I cannot even tell there is a locker in either truck, except in tight turns in parking lots. I will say that the Lock-Right does make itself known a bit more often in normal driving though.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 10-24-2009, 01:49 AM   #9
hotrod 80
mini truck racer
hotrod 80's Avatar
On a new install pinion depth and preload get set first . 0.003 is to tight you'll find the ring gear to have "tight" spots when that tight . I try and stay around .008-.010 . On a used gear the backlash must be set back to where it was before disassembly .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 10-24-2009, 09:09 AM   #10
I love them.You just have to drive like you have a locker...drift the corners and be aware of why these aren`t in every vehicle,your average driver.it takes paying attention to what you`ve got and that`s alot to ask of most people,it seems.I`m all about what I`m driving,so that`s second nature for me.
i`ve never noticed any difference in fuel consumption and my tires never suffer.I rotate every 5,000 miles anyway.I had two `72 3/4t 4wds,a Chevy (No-Spin/locker) and a GMC (Lok-Right/limited slip).The Chevy had 4.10s,35s,4spd,and SBC400.The GMC has 3.54s,33s,TH350,and 350.Both trucks got 12.5 mpg.If I hit the throttle a bit heavy (just a bit) pulling out while turning in my GMC,the inner tire chirps.
Old 10-24-2009, 11:38 AM   #11
LONGHAIR
I ran a Detroit in a 14bolt FF with a 454 and SM465 4 speed for several years. I drove it on the street and off road with 40" Regul Trailblazers and pulled with it a few times with some 35" Ground Hawgs. It never got what you would call good mileage, but I wouldn't say it was the locker's fault. It would growl the tire if you didn't "coast" a turn on the street, you always knew it was back there. I just had to drive it like it was there. I can be done, it's just not the greatest thing for a daily driver.
Old 10-24-2009, 11:56 AM   #12
turp mcspray
turp mcspray's Avatar
If you corner with enough throttle to "lock" it , both tires will be turning at the same speed, which means that one of them binding on the pavement. This extra drag is what hurts fuel mileage. On tires it is most noteable on the right rear because right turns are tighter than left, causing your right tire spin on the pavement when it's turning at the same speed as the left, but traveling a shorter distance. I wouldn't run anything but a locker in my 4wd. You just need to adjust your driving habits to cut down on tire wear and other "quirks" associated with a locker.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 10-24-2009, 07:33 PM   #13
MikeB
MikeB's Avatar
I just installed a Auburn posi in my 60 C-10. Even though I used my old R&P, I replaced the pinion bearings and races, as well as the carrier bearings and axle bearings. Had I not done that, it would have been fairly easy.
If you've never done it before you will need to read, read, read, all the articles you can find, like those on the Richmond Gear and Randy's Ring & Pinion websites.
I have lots of specialty tools and a 12-ton press, and I don't know how you'd install carrier bearings w/o a press. If you replace the pinion bearings and races, count on another 3-4 hours. You will need a very long pipe wrench to hold the pinion yoke in place while you hit the pinion nut with enough torque (300-400 lb/ft) to compress the crush sleeve to set pinion bearing pre-load. You'll also need a 0-60 in/lb torque wrench to measure pinion bearing pre-load.
The easy part is setting backlash, and I just spent 2-3 hours earlier today doing that until I got the shim packs just right.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 10-24-2009, 07:38 PM   #14
MikeB
MikeB's Avatar
One hour???? Are you bionic?
Mike
