06' Silverado SS Rear-end (Diff.) swap.
has anyone done this swap on a 70-72 2WD Blazer or 67-72 C10?
I have this rearend, it came off from my motor donor truck , its an 06' Silverado SS model, the rearend differential its a 2WD w/drum brakes ! |
Future TOTM Winner
Re: 06' Silverado SS Rear-end (Diff.) swap.
I have seen some of those trucks with the 14 bolt semi-floating axle and some have the regular 1/2 ton 10 bolt axle. Just curious which one you have?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
I ran a '98 14bff in my blazer.
Critter:
my rearend came off of an 06' SS Silverado 2WD with drum brakes and its a 14Bolt, anyone has the specs. of this particular rearend (differential)? is it possible to swap it to my 2wd K5? thanks. |
#5 | |
Why not just break out a tape measure and measure the perches, width ...etc? ![]() Last edited by vtblazer; 10-29-2009 at 06:52 PM. |
i know that rear is a direct swap into a 98 body style but not sure on the older ones. most likely it's a 3.73 rear.
also that truck is AWD
69 4wd V6 20k orig miles!! ![]() 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. ![]() 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com |
#7 | |
Future TOTM Winner
