Old 10-30-2009, 07:54 PM   #1
Shaffer4
Strange Cousin From The West..
Dana 44 Axle shaft interchange?
I still need to replace the Drivers side stub shaft on my '71 framed ('67 cab/title) 3/4 ton truck. finding one of these pieces is a pain in the @$$, from what I am reading is that the '73 and later axle shafts can be used. What particular years should I be looking for if I want to replace them, and will it work with the 3/4 ton axles?
Shaffer4 is offline   Reply With Quote
Old 10-30-2009, 09:04 PM   #2
Shaffer4
Re: Dana 44 Axle shaft interchange?
Okay, So I found some replacements on Ebay. Stupid question #2, would it be safe to only replace the driver side assembly?, as money is tight at the moment and then eventually replace the passengers side when funding allows?
Old 10-31-2009, 02:57 AM   #3
72blue
72blue's Avatar
not at all
James
72blue is offline   Reply With Quote
Old 11-01-2009, 08:38 AM   #4
ghettoluxury
ghettoluxury's Avatar
If it aint broke don't fix it!
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 11-01-2009, 02:06 PM   #5
Shaffer4
what I am saying is that I am going to put a '73- axle assembly in the driver's side and leave the early style axle shaft on the other side, I just wonder if the different u-joint sizes would cause any balance problems.
Old 11-01-2009, 05:09 PM   #6
2tons of fun
you are talking about 1-2oz at the most, how much do you weigh and do you counter balance you weight with balast on the pside?
yes the ENTIRE axle sahft assembly will swap with no issues. like you said you dont want to mix a old inner with the small joint with a newer outer with a big joint.
2tons of fun is offline   Reply With Quote
Old 11-02-2009, 09:25 PM   #7
cobinder
Everything is work in progress
cobinder's Avatar
Go to this site and be sure your geting the right parts.
http://www2.dana.com/pdf/XGI.PDF
Good luck with your truck!
How much?! It's just an old truck part!!
49 International on a 80 GMC 3/4ton 4x4 chassis
48 International KB-5 2 ton dump bed
04 Honda CRF "500"
09 Honda CRF450 fuel injected rocket
03 Suzuki hayabusa carbonfiber wheeled monster.
02 Ford diesel stretch van (toy hauler)
01 38' Monaco diesel pusher motorhome
cobinder is offline   Reply With Quote
