Air Bag Tank Size ?
Im in the UK and just about to order my air bag components, however im getting lots of different opinions on tank and compressor size,
1963 C10, Long Fleet, Small c notch out back, 2" drop spindles up front, I dont need the air system to go up & down fast, Just need to get her a bit lower when stationary, I had a 48 Ford with mustang 2 front end with air ride tec bags, 1 gallon tank, small compressor, all worked fine, 2-3 mins to refill tank. I was thinking the following, 4 X 6" bags, 1 x 3 gallon tank, thanks Last edited by roofingbloke; 10-24-2009 at 03:29 AM. Reason: spelling mistake |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Air Bag Tank Size ?
I have a 3 gallon tank on my blazer and wish I had a 5 gallon.
I just wish I could have a little more capacity.
Hi Lolife, Why do you think a bigger tank is required ?
What size pipes are you running. |
I am running only 1/4" airlines.
I just want more "switch time" without the compressor running.
One day.....
I'm running a 5 gallon tank with 1/2" lines and 2 compressors. Truck would lift and drop too fast for my liking so I put flow controls on both the aired up and aired out. Thinking about switching to (2) 3 gallon tanks. Not because of performance, just because I want to relocate my tank and it wont fit where i want it.
DZL1. Last edited by DZL1; 10-24-2009 at 09:23 AM. |
Im running a 5 gallon tank.. Search ebay for tanks. Mine came off an old city bus. 5 gallon 3 port tank for $11 bucks.
Happy to be here
![]() Join Date: Mar 2000
One 3 gallon tank is going to be rather small. If it's possible to fit a single 5 gallon, or two 3 gallon I think you will be happier.
If a single 3 gallon is your only option, consider a compressor with a high PSI rating. This will at least allow you to pack as much air in the tank as possible.
I'm also using a 5 gallon tank with 3/8 lines and 1 compressor. Works fine for what I want.
Just been on the ridetech website & there kit comes with a 3 gallon tank ?
So i was just thinking there must be a good reason thet all u guys seem to go with 5 Gallon tanks. |
Redefining LowBudget
I think a good set up would be a 5 gallon tank and 2 compressors keeps the run time down on the compressors....they suck to listen to...just remeber the comp's are hard on eletical systems they draw like 16 amps each
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
#11 | |
Happy to be here
I think most will agree that the worst part of an air suspension is listening to the compressor run. I have mine mounted at the very rear of the truck with the filter remote mounted and it's still annoying.
Reply to Hottrucks, Thanks for the reply. Question one pump runninf for 3 mins drawing 16 amps or two pumps running for 1.5 mins drawing 32 amps ??
which ever you choose just be sure to wire them acordingly...I have one comp and it it fails I'm stuck at least with two...well you get it
Happy to be here
Be sure if you run two compressors, that you use a relay.
#15 |
GM ONLY BABY!!!
You can never have enough. The bigger the better. Depends on the amount of room and your mounting location. I have 2 5gal. tanks and still wish I had more.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
#16 |
My old s-10 i had had a 5 gal I liked it the comprise would fill it real fast and not get to hot doing it I got all my air ride stuff from Jason at http://www.*****************/
nice guys and great prices Last edited by mr mike; 10-27-2009 at 02:12 AM. |
#17 |
I'm running a gallon tank and one Viair 400C compressor right now. It works just fine. I can raise my truck up once before the compressor kicks on. I'm running 1/2" lines with 3/8" Big Red valves, and a 135/150 pressure switch.
[IMG][/IMG]
First and Foremost: Thank you God for my Salvation! I pray that others will seek your Son, Jesus Christ! My 63 Double Dropmember Build "Project Sub-Zero": http://67-72chevytrucks.com/vboard/s...42#post5050342 My 2013 Camaro 1LE: https://www.youtube.com/channel/UCxa...wL5d6RnmfdJa1A 86 C10 "Build Thread”: http://67-72chevytrucks.com/vboard/s...d.php?t=668777
#18 |
Resistance is Futile
I'm impatient and went with 2 Viair 400's (almost 5cfm IIRC). I originally had a 6gal tank and after filling the compressors would not turn on at all after numerous adjustments. My compressors pull 50amps...so what, you have to wire them anyway
![]() I re-did my set-up with a 5gal tank and 2 re8's at the rear. I used 3/8's line to the back, also, for a little bit more control. After airing up the bags, my compressors now kick on for just a minute to replenish the tank. The re8's really eat more air.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
