Old 11-12-2009, 03:04 PM   #1
JCampbell
A few questions regarding doors...
1-What is involved in swapping over power doors from a ‘81-‘91 cab to a non-power '77 truck? Specifically the wiring. Is it a plug-and play set up?
2-Does anyone have any experience with the ‘replacement’ door panels offered by LMC, Classis, et al? What is the fit and finish like? Anyone have any real world pics? It’s hard to tell looking at the pics in the catalogs.
JCampbell is offline   Reply With Quote
Old 11-12-2009, 03:13 PM   #2
joe231
joe231's Avatar
Re: A few questions regarding doors...
does your '77 have blade type fuses in the fuse block?
you just need the power windows/locks wiring in the doors and the harness that runs under the dash along with the lock relay mounted under the steering column (kinda a PITA to get to). there are 3 wires on the harness that have to be hooked up. A constant hot, a switched hot, and a ground wire. if your fuse block has the blade type fuses, it should have places to pug in the 2 hot wires, the plugs on them will only allow them to be plugged into the proper spots, and the ground plugs onto a ground buss behind the instrument cluster. It is pretty simple. you will probably need to drill holes in the cab to hook up the rubber wireway to run the wires into the cab.
I have a thread about it around here somewhere.....
as far as the door panels, I have no experience with them.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 11-12-2009, 07:23 PM   #3
JCampbell
No, they are the glass-cylinder type(the name escapes me right now).
Sounds like more work than I'm willing to do right now. Honestly, with ice cold A/C, power windows are really not that high on my priority list.
Old 11-12-2009, 10:06 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
..... you will probably need to drill holes in the cab to hook up the rubber wireway to run the wires into the cab....
FYI- If you want to do it right, you will need to pull the doors to cut the holes large enough to use the factory accordion boot.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-12-2009, 10:27 PM   #5
onelow1ton
onelow1ton's Avatar
yeah thats what i did on my 85 crew cab dually but i also had the cross over harnes so it was a some what easy swap
onelow1ton is offline   Reply With Quote
Old 11-13-2009, 01:06 AM   #6
joe231
joe231's Avatar
He was talking about swapping doors, so they would be off anyway, and I said probably because my '80 doesn't have power doors but it already has the "accordion boots" (thanks for that, i couldn't think of what to call them )
CHEVY ONLY
Old 11-17-2009, 03:47 PM   #7
JCampbell
So nobody has any pics/experience w/ the "replacement" door panels?
Old 11-17-2009, 04:14 PM   #8
PlowBoy98
replacement panels are a pain in the butt if you don't have the body shop tools involved but it can be done. need a welder or a set of torches to melt down the lead to re attach door skins so..... you do the math is it something you are willing to invest the time in right now as it could take a few days and if you intend on doin the pain and body work also it will take even longer. an experienced body man could change the door skins for ya in a few hours though if he has all the tools involved. hope what little insight i have helps ya
PlowBoy98 is offline   Reply With Quote
Old 11-17-2009, 04:16 PM   #9
joe231
joe231's Avatar
think he is talking about interior door panels....
CHEVY ONLY
Old 11-17-2009, 04:18 PM   #10
PlowBoy98
oh gotcha. well then i have no clue as i am goin to be buying some myself here pretty soon lol
Old 11-17-2009, 04:56 PM   #11
JCampbell
Yeah, interior panels.
Sorry for the cornfusion.
