Old 12-11-2009, 06:18 PM   #1
DT1
DT1's Avatar
Grill and Tailgate Molding Paint
My 71 Cheyenne has a black border around the grill molding and black around the headlights. The moldings in all of the pictures I've seen so far are plain polished aluminum with no black. Did some come with the black or is this something the PO did to it?
The wide aluminum molding on the tailgate is just polished aluminum with wood grain but I've seen pictures of twin black stripes above and below the wood grain on some. Anybody know what's correct?
DT1 is offline   Reply With Quote
Old 12-11-2009, 07:45 PM   #2
OldSkool71
C/10 CLUB MEMBER
OldSkool71's Avatar
Re: Grill and Tailgate Molding Paint
that is correct for the front grille surround on a 71...as for the rear panel if it had woodgrain it should have black above and below it as well.
-Ron-
OldSkool71 is offline   Reply With Quote
Old 12-11-2009, 10:57 PM   #3
71 super
71 super's Avatar
All the replacement grills (GM and aftermarket ) are setup for 72 trucks if you want the stripe back you will have to put it there. To do this get a red scotch brite pad and scuff the section, use a quality etch primer and krylon 1651 (I think) semi gloss black and spray. Works great and holds up very well.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 12-11-2009, 11:16 PM   #4
DT1
DT1's Avatar
Ok, Thanks. So from what I gather, the 71 should have black on the grill?
Just want to make sure.
Old 12-11-2009, 11:20 PM   #5
72 Super
72 Super's Avatar
yes 71's came with black outline on the outter grill shells from the factory .
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White
72 Super is offline   Reply With Quote
